ok so in one of my device types i have the following preference code
preferences {
input("manualmode", "enum", title: "Default Manual Overide Method", options: ["TADO_MODE","MANUAL"], required: false, defaultValue:"TADO_MODE")
input("defHeatingTemp", "number", title: "Default Heating Temperature?", required: false, defaultValue: 21)
the default value of the preference is not as stated (its null) until i go into the device and select the value and save it even though that value is displayed in the preference box… should this be the case? i thought this worked previously without having to go into the device prefs and save, or do i need to check for null values in my code and set the default there also?!? @jody.albritton am i mistaken that this used to work fine?
