Hi This model BE469WKVCAM619 will work with smart Things hub?
Yes I have the same lock in Satin Nickel finish. Have had no issues since I installed it. Probably my family’s favorite thing I have installed.
I believe there is native support for this lock. I personally use @RBoy software to manage mine.
I use Smart app #1 and Device Handler #4 .
If you go with RBOY code you’ll have to pay for it. Some people choose not to. I believe there is a free custom DTH for this lock too. I don’t use that so someone else might be able to point you in that direction.
Hope that helps.
jkp
December 30, 2016, 3:25pm
3
The free DTH that Don alluded to can be found in the following posts.
Beta version
Lock Manager
Incomplete List of features:
Manage user codes on locks.
Manage Keypads.
Review and manage active lock codes.
Set lock access based on schedules.
Receive notifications when a user used their code.
Run Hello Home phrases based on lock/unlock events.
Manage Hello Home phrases based on keypad inputs.
This app works using 3 child apps and 1 parent app. It is recommended that you install all 4 apps, however if you do not use keypad devices, it is not required to install the keypad child app.
Note: If upgrading from any beta version, it is required to uninstall the app completely before installing. The architecture of this app has changed in
a way that is incompatible with previous versions.
How To Install
User guide has old information. There is now only one app to insta…
older version
There’s a new app!
Please go to this thread for the new Lock Manager App, which is in active development.
##Legacy App:
This app is no longer being maintained. Support and bug fixes are no longer being provided.
Welcome to Lock Manager!
Now with custom device type!
Use the attached device type zwave-lock.groovy for added functionality.
Minimal changes to SmartThings code.
More reliable code set/delete.
Codes will be reconciled on each poll() event.
App will function without custom device type, but not as well.
Features:
Assign Codes to Multiple Users.
Manage Multiple Locks.
See what codes are active.
See how many times a code is used (reset usage manually)
Be notified when a user uses their code.
Delete codes after they are used*.
Optionally Schedule Users so that they only have ac…
