I searched for this but didnt come up with anything…
I’m working on a smartapp – In the preferences section I have defined a date type input. When this is run, and you focus on that field, you just get a keyboard, rather than a datepicker of some sort. For ‘time’ type fields, I’ve noticed you get a simple time picker.
This is both in the simulator and in android app, so I don’t think that it is a bug in the simulator.
Am I missing something? The date input gives no indication of the format of date required either.
Thanks,
Jake
RBoy
2
@jacobrichard did you figure this out, I’m facing the same issue. When I enter type “date” I get a keyboard input with no indication on format.
RBoy
3
@Jim - can you comment on this from a docs point, what is the expected format for input “date” and what is the expected screen layout for the user - wondering if we are using this correctly since I can’t find examples using dates either.
Yep, I’m looking into it. As you have noticed, we don’t have a date picker. It may be that we need to remove this from the documentation. I’ll follow up.
I am curious about the use case for specifying a date value in a preference. Can people share their requirements? Is it to execute something only on a certain day in the future, or…?
I’m working on a lock manager that could benefit from a date field. The idea is a vacation home landlord, such as someone who does Air B&B could then choose a date to start code access, and also a date to end code access automatically with my app.
As it is now, I’ll have to ask for each day/month/year individually, parse that into a date and then somehow add time to it, either with the time field and parse out the date (since the time field also captures a date… argh) or ask for yet alother individual value: 24 hour time… such as 1300, or 1301 for 1:00pm, or 1:01pm respectively. Not the most user friendly experience, and definitely not fun to program these dateTimes out manually.
Here’s a code example of the input: Input Preference Fields
Here’s how I got around to parsing the date with the time input field cut in: Parse Date Method
Here’s the schedule call for the parsed dateTime: Run Once Method
Another vote for a date type input. My Smartapp will let me trigger an event (thermostat to mode/temp) once at a specific date and time and then confirm it a few hours later. I’ve reused the great code @ethayer shared to get it working for now but a date or date+time input type would be much more user friendly.
