This is my first post in the forum, so please bear with me as I’m sure this has been covered multiple times. Just can’t seem to find a definitive solution and a good portion of the threads relating to graphing seem to be a bit older.
I have to say I’m a bit frustrated at this point with something so simple and basic. The only thing I’d like to see is a graph of the data being pulled from my devices…
I’ve setup and successfully logged data via SimpleEventLogger, but haven’t got a decent graph to populate… I’m still working on this in my spare time, but before I allocate any further efforts I’d like to know if theres a simpler solution?
Looking into Initial State, Groove Streams and the rest of the bunch outlined in the Data Logging Roundup. I don’t have a server. I know very little code. I plan on educating myself as I go, but for now I need something setup and graphing.
So before I sign up and start piddling with the different services, what do you guys recommend?
I really appreciate your time and thank you for the wealth of knowledge contained within this community!
If you don’t have a server this won’t help a lot but I use the InfluxdB logger to send metrics to an Influx database then use Grafana to create the graphs. You can find examples on the forum searching for those products. I send the data to an AWS server but you could use a PC at home if it’s up all the time.
