@625alex i found a way yo use smartTiles yo control the device audio, just need yo use tasker and the url yo the command awesome, i got my speakers connected via Bluetooth to the SmartTiles Tablet ;)AWESOME , DIDNT HAVE TO PAY FOR SONOS
Ok, letās try something different, this should work, I promise:
.dashboard.tile[data-link-i="1"] .icon a i::before {content: "ļ";}
nth-child(1) is the first dashboard link.
Thatās great. This is one of many ways of doing it.
This is a fantastic use case btw, control audio of the device that displays the dashboard itself. I will write about it on the site.
I copied your 3 alarm switches and they do look cool. The only problem I have is when you press the switch. The mode doesnāt change to reflect the state of the switch. So I assume the switches are just for monitoring the status of the alarm? Or am I missing something?
Sorry to keep bothering you about this. Do I just need to change the .st-dashboard to .st-shortcut to make this work for URL shortcut tiles? Could you paste an example of what the code should specifically look like? I just canāt seem to get it to work.
.st-link:nth-child(1)::before {content: "ļ²"}'
This is what I am inputting to change the icons on my 3 url links, can you tell me what iām doing wrong?
.st-link:nth-child(1)::before {content: "fa fa fa-step-backward"}
.st-link:nth-child(2)::before {content: "fa fa-play"}
.st-link:nth-child(3)::before {content: "fa fa-step-forward"}
Should be
.st-link:nth-child(1)::before {content: "ļ"}
Copy/paste the actual icon of interest, not the icon alias/label. The sample above renders icon as a square, the dashboard has the necessary plumbing to display the proper icon.
Ok I think iām missing something, are we still supposed to reference the icons in font awesome? How do you copy and paste the icon? I Just copy and pasted your square in your example and it showed up as the step backward, the icon i wanted. But what format is that in?
I figured it out! I use the unicode they have underneath the icon and find the appropriate image and viola! Just as you said, Thanks so much! One last thing, however. Despite having nth-child(1), nth-child(2) and their individual icons, they all just match the first nth-child(1) icon. How do I get them so they each display their own icon?
Thanks again, your support is incredible!
Thank you very much, this worked perfect!
Ok, I retract my previous code bit and I shouldnāt look at code after midnight anymore. Try the following bit:
data-link-i=ā1ā is in the same order as defined in the SmartApp preferences.
I may have missed a post. Is there a link to available icons?
@625alex, this worked great. I have tried with multiples and it works fine but have a quick question.
How would it work with dashboard links and urls on the same screen.
Using this:
it looks like ādata-linkā is for dashboard links and urls. Would this work with both on the same dashboard? How would you use data-link-i=ā1ā, data-link-i=ā2ā, etcā¦
Scott
No, the mode should change on click too. Can you post a copy of one of your virtual switches? You can pm me too if you donāt want to clog up this thread.
Thanks for the response @swindmiller . I think the problem was caused by my wife renaming the mode. I will give it another go once sheās done and happy with the names. It will probably we a while I am pretty sure
No problemā¦let me know if I can help
Someone was asking about inexpensive waterproof tablets so they could put smarttiles on a table by the pool. I canāt find that particular comment right now so Iāll post this here.
As far as I know all the waterproof tablets are very expensive. However there are many waterproof cases which are a much less costly solution.
The bubbleshield for example runs less than $20, and seems to work well. Itās kind of goofy looking but would be appropriate for poolside. And, yes, you can use the tablet while itās still in the case.
This first link is to review site covering a number of waterproof cases:
And this is the bubble shield at Amazon:
In case anyone is curious if you want to change the color for the dimmer light use this code:
.dimmerLight.active .icon {color:#FFFF00}
This one will not change anything!
.dimmer.active .icon {color:#00FF00}
