diehllane
(Brian Diehl)
December 11, 2016, 3:10am
2
Here’s a guide on different ways of detecting presence (some of which are virtual)
You may want to look at the bottom post which has information about a virtual device that is a presence sensor and a switch (so it can be turned on and off).
Presence, regardless of the device you use, is one of those features that works great for some people, not at all for other people, and is randomly flaky for still others.
It’s very much affected by local conditions. So some people will find that phone presence works much better than the SmartThings-branded presence sensor. Other people will find the reverse. Still other people, myself included, find that they have to use a combination of two devices in order to get reliable presence indication.
So if this feature tends to work differently for different people, where do you start?
1. Using a Smart Phone as a Presence Indicator
[image]
Well, since most people who have SmartThings have a smart phone, it’s worth starting there.
This method has changed significantly in the change fro…
