Creating a security system using SmartThings
(Joel W) #1
What do I need to build an alarm using SmartThings? I plan to use only motion detectors and a few door switches that have to have a delay before setting off the alarm. I also need one keypad. What do you suggest and is there instructions to do this?
#2
I’m working on this. so far I have smartthings multi sensors for my windows and an ecolink door open/close sensor. i’ll probably be getting a couple more multisensors and door sensors. i don’t have motion sensors but i believe people like the aeon model because you can change the jumper to ignore pets. there are also a couple alarms out there but i’m not there yet.
one thing i like is that i’ve added my foscam cameras to the system so if, for example, the front door opens the camera in the livingroom takes a couple pictures.
an app that helps with this is Magic Home
which gives more flexibility for states. I currently have my motion sensor notifications on for day-away and night-away. use presence sensors and this and it’s a pretty good system.
(Geko) #3
(Joel W) #4
Thanks I will look into this.
