Creating a color changing bulb/bulbs app
Hi,
I want to write a simple app to change colors of selected bulbs according to a preprogrammed color loop.
I wrote it partially. Bulbs are selected and the first color command is set to the bulbs.
Now I want to change the color to the second in the queue. But I don’t know how to create the queue and how to read from it with a given period of time.
What could be the best practice to achieve this ?
Currently my app asks the bulbs to use in the program and number of actions.
Then each action is configured with 3 parameters (color, level, duration)
these parameters are stored in variables :
p_1_color, p_1_level, p_1_duration
p_2_color, p_2_level, p_2_duration
where 1,2,… are the action numbers.
these are read from the settings page with “input” commands.
also an event is configured (motion , button etc.)
when the event is triggered, it calls a function.
the problems are ;
  1. I don’t know how to read these values which are set
  2. how to use them according to the duration configured in each action (I have to set a timer but how)
  3. how can I pass to the next color when the timer is expired ?
also, can I make it looping forever ? (if yes, how can I stop it)
If you post your code so far I will try and help you
Andy
sure , here it is :
definition(
    name: "Color Changing Bulbs",
    namespace: "smartthings",
    author: "SmartThings",
    description: "Change color of bulbs in a defined pattern",
    category: "SmartThings Labs",
    iconUrl: "https://s3.amazonaws.com/smartapp-icons/Partner/sonos.png",
    iconX2Url: "https://s3.amazonaws.com/smartapp-icons/Partner/sonos@2x.png"
preferences {
	page(name: "mainPage", title: "Color Changing Bulbs", install: true, uninstall: true)
    page(name: "configureAction")
	page(name: "timeIntervalInput", title: "Only during a certain time") {
		section {
			input "starting", "time", title: "Starting", required: false
			input "ending", "time", title: "Ending", required: false
def mainPage() {
	dynamicPage(name: "mainPage") {
        section("Control these bulbs...") {
		input "hues", "capability.colorControl", title: "Which Hue Bulbs?", required:false, multiple:true
                section("Actions") {
                input "numberOfActions", "enum", title: "Number of Actions?", required: true, submitOnChange: true, options: [
                1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24]
                def configDescription = ""
                for (int i = 1; i <= (settings["numberOfActions"] as Integer); i++){
                   if (settings["p_${i}_color"] != null) {
                      configDescription = configDescription + "p_${i}_color" +":"
                   if (settings["p_${i}_lightLevel"] != null) {
                      configDescription = configDescription + "p_${i}_lightLevel" +":"
                       if (settings["p_${i}_duration"] != null) {
                           configDescription = configDescription + "p_${i}_duration" +":"
                   if (configDescription == ""){
                      configDescription = "Click to configure"
                   href "configureAction", title:"Configure Action", description:"$configDescription", params: [paction: i]
		def anythingSet = anythingSet()
		if (anythingSet) {
			section("Play weather report when"){
				ifSet "motion", "capability.motionSensor", title: "Motion Here", required: false, multiple: true
				ifSet "contact", "capability.contactSensor", title: "Contact Opens", required: false, multiple: true
				ifSet "contactClosed", "capability.contactSensor", title: "Contact Closes", required: false, multiple: true
				ifSet "acceleration", "capability.accelerationSensor", title: "Acceleration Detected", required: false, multiple: true
				ifSet "mySwitch", "capability.switch", title: "Switch Turned On", required: false, multiple: true
				ifSet "mySwitchOff", "capability.switch", title: "Switch Turned Off", required: false, multiple: true
				ifSet "arrivalPresence", "capability.presenceSensor", title: "Arrival Of", required: false, multiple: true
				ifSet "departurePresence", "capability.presenceSensor", title: "Departure Of", required: false, multiple: true
				ifSet "smoke", "capability.smokeDetector", title: "Smoke Detected", required: false, multiple: true
				ifSet "water", "capability.waterSensor", title: "Water Sensor Wet", required: false, multiple: true
				ifSet "button1", "capability.button", title: "Button Press", required:false, multiple:true //remove from production
				ifSet "triggerModes", "mode", title: "System Changes Mode", required: false, multiple: true
				ifSet "timeOfDay", "time", title: "At a Scheduled Time", required: false
		def hideable = anythingSet || app.installationState == "COMPLETE"
		def sectionTitle = anythingSet ? "Select additional triggers" : "Play weather report when..."
		section(sectionTitle, hideable: hideable, hidden: true){
			ifUnset "motion", "capability.motionSensor", title: "Motion Here", required: false, multiple: true
			ifUnset "contact", "capability.contactSensor", title: "Contact Opens", required: false, multiple: true
			ifUnset "contactClosed", "capability.contactSensor", title: "Contact Closes", required: false, multiple: true
			ifUnset "acceleration", "capability.accelerationSensor", title: "Acceleration Detected", required: false, multiple: true
			ifUnset "mySwitch", "capability.switch", title: "Switch Turned On", required: false, multiple: true
			ifUnset "mySwitchOff", "capability.switch", title: "Switch Turned Off", required: false, multiple: true
			ifUnset "arrivalPresence", "capability.presenceSensor", title: "Arrival Of", required: false, multiple: true
			ifUnset "departurePresence", "capability.presenceSensor", title: "Departure Of", required: false, multiple: true
			ifUnset "smoke", "capability.smokeDetector", title: "Smoke Detected", required: false, multiple: true
			ifUnset "water", "capability.waterSensor", title: "Water Sensor Wet", required: false, multiple: true
			ifUnset "button1", "capability.button", title: "Button Press", required:false, multiple:true //remove from production
			ifUnset "triggerModes", "mode", title: "System Changes Mode", required: false, multiple: true
			ifUnset "timeOfDay", "time", title: "At a Scheduled Time", required: false
		section("More options", hideable: true, hidden: true) {
			input "frequency", "decimal", title: "Minimum time between actions (defaults to every event)", description: "Minutes", required: false
			href "timeIntervalInput", title: "Only during a certain time", description: timeLabel ?: "Tap to set", state: timeLabel ? "complete" : "incomplete"
			input "days", "enum", title: "Only on certain days of the week", multiple: true, required: false,
				options: ["Monday", "Tuesday", "Wednesday", "Thursday", "Friday", "Saturday", "Sunday"]
			if (settings.modes) {
            	input "modes", "mode", title: "Only when mode is", multiple: true, required: false
			input "oncePerDay", "bool", title: "Only once per day", required: false, defaultValue: false
		section([mobileOnly:true]) {
			label title: "Assign a name", required: false
			mode title: "Set for specific mode(s)"
def configureAction(params) {
   if (params.paction != null) state.currentAction = params.paction.toInteger() //log.debug "$params.pbutton"
   dynamicPage(name: "configureAction", title: "Choose the actions for Program${state.currentAction}.",
   getActionSections(state.currentAction))
def getActionSections(actionNumber) {
	return {
		section("Color") {
			input "p_${actionNumber}_color", "enum", title: "Light Strip Color?", required: false, multiple:false, submitOnChange: true, options: [
					["Soft White":"Soft White - Default"],
					["White":"White - Concentrate"],
					["Daylight":"Daylight - Energize"],
					["Warm White":"Warm White - Relax"],
					"Red","Green","Blue","Yellow","Orange","Purple","Pink","Cyan","W1","W2","Random","Custom","Off"]
            if (settings["p_${actionNumber}_color"] == "Custom"){
                input "p_${actionNumber}_custom", "text", title: "Custom Color in Hex (ie ffffff)", submitOnChange: false, required: false
        if (settings["p_${actionNumber}_color"] != "Custom"){
            section("Level"){
                input "p_${actionNumber}_lightLevel", "number", title: "Light Level?", required: false, range: "1..100"
        section ("Duration"){
                input "p_${actionNumber}_duration", "number", title: "Duration (milliseconds)", range: "100..1000000", submitOnChange: false, required: false
private anythingSet() {
	for (name in ["hues","motion","contact","contactClosed","acceleration","mySwitch","mySwitchOff","arrivalPresence","departurePresence","smoke","water","button1","timeOfDay","triggerModes"]) {
		if (settings[name]) {
			return true
	return false
private ifUnset(Map options, String name, String capability) {
	if (!settings[name]) {
		input(options, name, capability)
private ifSet(Map options, String name, String capability) {
def installed() {
	log.debug "Installed with settings: ${settings}"
	subscribeToEvents()
def updated() {
	log.debug "Updated with settings: ${settings}"
	unsubscribe()
	unschedule()
	subscribeToEvents()
def subscribeToEvents() {
	subscribe(app, appTouchHandler)
	subscribe(contact, "contact.open", eventHandler)
	subscribe(contactClosed, "contact.closed", eventHandler)
	subscribe(acceleration, "acceleration.active", eventHandler)
	subscribe(motion, "motion.active", eventHandler)
	subscribe(mySwitch, "switch.on", eventHandler)
	subscribe(mySwitchOff, "switch.off", eventHandler)
	subscribe(arrivalPresence, "presence.present", eventHandler)
	subscribe(departurePresence, "presence.not present", eventHandler)
	subscribe(smoke, "smoke.detected", eventHandler)
	subscribe(smoke, "smoke.tested", eventHandler)
	subscribe(smoke, "carbonMonoxide.detected", eventHandler)
	subscribe(water, "water.wet", eventHandler)
	subscribe(button1, "button.pushed", eventHandler)
	if (triggerModes) {
		subscribe(location,modeChangeHandler)
	if (timeOfDay) {
		schedule(timeOfDay, scheduledTimeHandler)
	if (song) {
		saveSelectedSong()
def eventHandler(evt) {
	if (allOk) {
		log.trace "allOk"
		def lastTime = state[frequencyKey(evt)]
		if (oncePerDayOk(lastTime)) {
			if (frequency) {
				if (lastTime == null || now() - lastTime >= frequency * 60000) {
					takeAction(evt)
				else {
					log.debug "Not taking action because $frequency minutes have not elapsed since last action"
			else {
				takeAction(evt)
		else {
			log.debug "Not taking action because it was already taken today"
def modeChangeHandler(evt) {
	if (evt.value in triggerModes) {
		eventHandler(evt)
def scheduledTimeHandler() {
	eventHandler(null)
def appTouchHandler(evt) {
	takeAction(evt)
private takeAction(evt) {
	loadText()
	if (frequency || oncePerDay) {
		state[frequencyKey(evt)] = now()
private frequencyKey(evt) {
	"lastActionTimeStamp"
private dayString(Date date) {
	def df = new java.text.SimpleDateFormat("yyyy-MM-dd")
	if (location.timeZone) {
		df.setTimeZone(location.timeZone)
	else {
		df.setTimeZone(TimeZone.getTimeZone("America/New_York"))
	df.format(date)
private oncePerDayOk(Long lastTime) {
	def result = true
	if (oncePerDay) {
		result = lastTime ? dayString(new Date()) != dayString(new Date(lastTime)) : true
		log.trace "oncePerDayOk = $result"
	result
// TODO - centralize somehow
private getAllOk() {
	modeOk && daysOk && timeOk
private getModeOk() {
	def result = !modes || modes.contains(location.mode)
	log.trace "modeOk = $result"
	result
private getDaysOk() {
	def result = true
	if (days) {
		def df = new java.text.SimpleDateFormat("EEEE")
		else {
		def day = df.format(new Date())
		result = days.contains(day)
	log.trace "daysOk = $result"
	result
private getTimeOk() {
	def result = true
	if (starting && ending) {
		def currTime = now()
		def start = timeToday(starting, location?.timeZone).time
		def stop = timeToday(ending, location?.timeZone).time
		result = start < stop ? currTime >= start && currTime <= stop : currTime <= stop || currTime >= start
	log.trace "timeOk = $result"
	result
private hhmm(time, fmt = "h:mm a")
	def t = timeToday(time, location.timeZone)
	def f = new java.text.SimpleDateFormat(fmt)
	f.setTimeZone(location.timeZone ?: timeZone(time))
	f.format(t)
private getTimeLabel()
	(starting && ending) ? hhmm(starting) + "-" + hhmm(ending, "h:mm a z") : ""
private loadText() {
def color ="Warm White"
sendcolor(color)
private list(String s) {
	[s]
private list(l) {
	l
def sendcolor(color) {
    def hueColor = 0
    def saturation = 100
	switch(color) {
		case "White":
			hueColor = 52
			saturation = 19
			break;
		case "Daylight":
			hueColor = 53
			saturation = 91
			break;
		case "Soft White":
			hueColor = 23
			saturation = 56
			break;
		case "Warm White":
			hueColor = 20
			saturation = 80 //83
			break;
		case "Blue":
			hueColor = 69
			saturation = 95
			break;
		case "DarkBlue":
			hueColor = 70
			break;
		case "Green":
			hueColor = 39
			break;
		case "Yellow":
			hueColor = 25
			break;
		case "Orange":
			hueColor = 10
			break;
		case "Purple":
			hueColor = 75
			break;
		case "Pink":
			hueColor = 83
			break;
		case "Red":
			hueColor = 100
			break;
	state.previous = [:]
	hues.each {
		state.previous[it.id] = [
			"switch": it.currentValue("switch"),
			"level" : it.currentValue("level"),
			"hue": it.currentValue("hue"),
			"saturation": it.currentValue("saturation")
	def newValue = [hue: hueColor, saturation: saturation, level:100]
	hues*.setColor(newValue)
Difficult to read and reply on an ipad but here goes…
I’ll answer your last question first
To switch on/off (to allow loop or not)
Create a virtual switch to turn the app on/off
Create a normal switch input then subscribe to it
input “switch1”, “capability.switch”, title: “Select switch to enable/disable app (Optional)”, required: false, multiple: false
// Subscriptions ********************************************************************
subscribe(switch1, “switch”, switchEnableNow) // Default - Enable/Disable switch
// Enable Switch Handler *********
// disable/enable switch
def switchEnableNow(evt){
state.enable = evt.value
You could add something like this to your allOk :
modeOk && daysOk && timeOk && enableOk
private getenableOk(){
def result = true
if(state.enable == ‘on’){
result = true }
else if(state.enable == ‘off’){
result = false }
result
This would mean once the switch was off any looping would stop .
You could also set all lights off within the " else if(state.enable == ‘off’){ " section to turn off everything when switch is turned off
ok. great. but I don’t know how I shall make it loop with the durations specified on the settings by user.
Have a look in the docs for the runIn() command
Basically…
myDelay = userInputdelay
runIn(myDelay, method)
ok. that I understand now. but I still can’t form the function to make my selected bulbs loop in a given color program.
I believe, I need a “for” loop for this , what else ?
how can I read the variables from the settings and set each bulb accordingly ?
I understand that you are out now. I am not in a hurry. If you can have a look later, that would be wonderful.
thx.
did you have some time to have a look at this ?
thx
this is not what I am looking for.
I want to create a program for all lights but each light will use different color at any point.
so ;
light1= color(i)
light2= color(i+1)
ight3= color(i+2)
take a look at this piston as an example. this sets each bulb to a different color so long as there are sufficient colors to bulbs:
how can I create an array and use elements from it ?
And the array should be available as a global variable.
thx.
I’m sorry but I’m not very well at the moment so cannot concentrate on code
Have a look at this as it may help you
http://docs.smartthings.com/en/latest/smartapp-developers-guide/state.html?highlight=Array
I hope you get well soon.
thanks.
I understood usage of arrays and state
but I have a problem:
now I have array named state.colors which has color names in it.
and I also have a state.where integer which shows at which color we are.
but the following is not accepted:
log.debug "${state.colors[${state.where}]}"
I get this error:
error groovy.lang.MissingMethodException: No signature of method: script_app_Color_Chan_d9c31961_fc2b_479e_bb33_e8255ab4878a_ver_7_8.$() is applicable for argument types: (script_app_Color_Chan_d9c31961_fc2b_479e_bb33_e8255ab4878a_ver_7_8$_loadText_closure4) values: [script_app_Color_Chan_d9c31961_fc2b_479e_bb33_e8255ab4878a_ver_7_8$_loadText_closure4@42f09407]
Possible solutions: is(java.lang.Object), now(), url(), run(), any(), app(java.util.Map)
also, this produces the same result:
int i = ${state.where}
following command gives the color name as the output:
log.debug "${state.colors[0]}"
what is wrong with the usage of integer type state ?
I’ve finally managed to solve the issue with state variable.
and added switch to enable/disable
they all work fine.
But , the loop does not continue forever.
For example , I set 5 actions. after the 5th action, it goes back to the first one.
But does not go the the 2nd.
here’s the full code :
definition(
preferences {
		section {
def mainPage() {
        section("enable/disable switch") {
        input "switch1", "capability.switch", title: "Select switch to enable/disable app (Optional)", required: false, multiple: false
		if (anythingSet) {
	return {
		section("Color") {
            section("Level"){
			return true
	return false
def installed() {
	subscribeToEvents()
def updated() {
   def colors = []
   def levels = []
   def durations = []
state.noa=settings["numberOfActions"] as Integer
for (int i = 1; i <= (settings["numberOfActions"] as Integer); i++) {
   colors << settings["p_${i}_color"]
   levels << settings["p_${i}_lightLevel"]
   durations << settings["p_${i}_duration"]
state.colors = colors
state.levels = levels
state.durations = durations
state.where =  0 as Integer
//log.debug "$state.colors $state.levels  $state.durations"
	unsubscribe()
	unschedule()
	subscribeToEvents()
	subscribe(switch1, "switch", switchEnableNow) // Default - Enable/Disable switch
	if (triggerModes) {
	if (timeOfDay) {
	if (song) {
		saveSelectedSong()
def result = true
if(state.enable == 'on'){
result = true }
else if(state.enable == 'off'){
result = false }
result
	if (allOk) {
		log.trace "allOk"
			if (frequency) {
					takeAction(evt)
				else {
			else {
				takeAction(evt)
		else {
		eventHandler(evt)
	eventHandler(null)
	takeAction(evt)
	loadText()
	else {
	df.format(date)
	def result = true
	if (oncePerDay) {
	result
	result
	def result = true
	if (days) {
		else {
	result
	def result = true
	result
	f.format(t)
int i = state.where
int j = state.noa
//log.debug "$state.where"
//log.debug "$state.where ${state.colors[i]}"
	hues.each {
		sendcolor(state.colors[i],state.levels[i],it)
        pause(200)
 		pause(state.durations[i])
        i++
		state.where=i
   //if (state.where < state.noa) {
  			if (enableOk) {goagain()}
private goagain() {
   if (state.where >= state.noa) {
   	state.where=0 as Integer
    loadText()
def sendcolor(color,level,bulb) {
	def hueColor = 0
	switch(color) {
		case "White":
			hueColor = 52
			saturation = 19
			break;
		case "Daylight":
			hueColor = 53
			saturation = 91
			break;
		case "Soft White":
			hueColor = 23
			saturation = 56
			break;
		case "Warm White":
			hueColor = 20
			break;
		case "Blue":
			hueColor = 69
			saturation = 95
			break;
		case "DarkBlue":
			hueColor = 70
			break;
		case "Green":
			hueColor = 39
			break;
		case "Yellow":
			hueColor = 25
			break;
		case "Orange":
			hueColor = 10
			break;
		case "Purple":
			hueColor = 75
			break;
		case "Pink":
			hueColor = 83
			break;
		case "Red":
			hueColor = 100
			break;
//	state.previous = [:]
	hues.each {
	def newValue = [hue: hueColor, saturation: saturation, level:level]
    bulb.setColor(newValue)
	//hues*.setColor(newValue)
