It has been discussed before, I think, that set color has dual action changes color and level. Is your level or color most important to you, or both transitions are a must?
I donât understand the question. Youâre right of course that Set Color sets hue, level, and saturation. But itâs irrelevant in this case, I think. All that piston does is, first, set the initial conditions (level and color). That works just fine. Then I tell it to transition to Warm White over the course of a minute. That doesnât work at all. It seems to me that it should.
I see, youâre right, it appears to be a bug, and youâre also right about the 60 seconds, at minimum itâs confusing that you are not warned that it cannot exceed 60s @ady624 do you need more logs?
Thatâs a great idea! Have been testing something similar, but just gradually bring up the level, not the color.
This works great. All of the lights change at the same timeâŚ
The only problem Iâve had is that the loop disdies not always break when the switch goes off. It takes several tries.
BREAK is part of WHILE or FOR loops, wonât work with repeat whole action - I mentioned before, a solution is required to stop that repeat whole action thing. Maybe a total count, or a break condition. BREAK does not currently affect the repeat.
Transition to color is a custom command of Hues. Iâve found that some hues implementation require 10ths of seconds as time parameter, some seconds. Try varying the number, try with 1, see if it has any effect - be patient, I think I multiply that with 1000 because my DTH wants msâŚ
I think I have the piston working for arrival and really like the wait command I had never used it before.
I will still need to figure out a separate piston for motion but this helps a lot.
Thanks,
Scott
If you want the fade to happen 7 minutes later, you need to put the Wait 7 minutes in a task right before the Fade, within the same action. It wonât do anything on its own.
Yeah, something is working. I noticed that sometimes the end color comes on, but I wasât able to get it to gradually transitionâŚOh wellâŚ
Gotcha⌠I think I understand⌠I will adjust it later tonight and see if I can figure out how to build it.
Sorry to qutoe myself, but, I could never get that to work the way I thought it should. So, I retried, using WAS NOT for 3 minutes instead of wait.
If any of Pres1 or Pres2 changes to present (trigger)
AND
Each of Pres1 or Pres2 is present (condition)
AND
Time is Day --> set mode to day
OR
Time is night --> set mode to night
ELSE-IF
Pres1 WAS NOT present 3 min --> set mode Pres1Away (cancel on piston change)
OR
Pres2 WAS NOT present 3 min --> set mode Pres2Away (cancel on piston change)
OR
Each of Pres1 or Pres2 is not present --> set mode AllAway
But, this way, the ELSE-IF never executes. Does the WAS NOT fail because the trigger is long past gone by the time the period of âWAS NOTâ is satisfied.
Any better ideas on how to do this?
The state of an ELSE IF piston will be true if any of the two conditions (IF or ELSE IF) is true. Use a latching piston on the first version and it will work. Then the piston is true if the top IF is true, false if the BUT IF is true.
Ady, can u elaborate on how to get this loop to stop? I have mimicked bamarayneâs rule and I cannot get it to stop.
Go into the dashboard and pause the piston. Our delete it.
OK, but what about his suggestion for a conditional break? Or a total number of count times. Did you get this figured out yet?
Iâm trying to set up some special color selections for the Hue bulbs in my front yard, based on holidays.
What Iâve written is basically:
Simple piston:
If time
Then -> follow up piston (1)
Else, basic warm white lights on
Follow-up piston (1)
If anytime during specific dates, if true action -> follow up color piston (2)
OR
If anytime during this other specific dates, if action true -> follow up color piston (3)
ELSE nothing
Follow up color piston (2)
If - nothing
Then - makes lights these colors
The idea is that different dates execute different specific follow up color Pistons.
BUT, I canât get the color Pistons to fire. Is it because thereâs nothing in the IF statement for the color piston?
Anyone have another way to do this??
I would use a follow up instead of repeat whole action
I just got home from work. Iâm gong to mess with this and Iâll post what I find out.
