Convert Electronic Switch to Mechanical (Bionaire Fan) for use with smart outlet
(Weston T Turner) #1
Hello all,
Would anyone here have the knowledge to help me with the subject. The fan I have is linked below.
I have some mechanical knowledge but I believe I need some baby steps laid out for me to help me on this one.
Essentially, I would like the fan to start upon plugging it into the wall rather than requiring the power button to be pressed after plugging it in.
I really don’t know where to start.
Thank you all for any help you can offer.
(Ray) #2
This could be tricky depending on what circuitry is inside the fan. If power is controlled by a relay then it’s probably not difficult to bypass but if this is a multi speed fan then it’s probably solid state which is not easy.
One other way to do this is to get an esp IR remote controller like this one.
(Weston T Turner) #3
Ray,
Thanks so much for the response. Sadly, as you said, it is a multi speed fan.
I actually own the harmony hub so I’m sure I could program one of the blasters to work the hub. I was just hoping I wouldn’t have to tie it to harmony and could streamline straight to smartthings with an outlet.
The more I learn about home automation, the more I realize, the less steps, the better.
Thank you for that link also, I had taken a look at it earlier and was afraid even that may be getting out of capabilities.
