Hey guys,
As mentioned earlier in this thread, here are the service and characteristic that you need to scan and read from:
const SERVICE = "00035b03-58e6-07dd-021a-08123a000300";
const CHARACTERISTIC = "00035b03-58e6-07dd-021a-08123a000301";
Note that you need to enable both notifications and indications for the characteristic, before writing to it.
Here are the commands I managed to intercept so far (I am using a JSON format as an example):
"turn_on": ["0d 07 84 0f 02 01 55 12",
"0d 07 84 0f 02 01 55 12"],
"health_check": ["0d 05 75 0f da 25"],
"machine_status": ["0d 08 95 0f 00 32 01 5d df", "0d 08 95 0f 00 3f 01 2b 83"],
"settings_cup_lighting_on": ["0d 0b 90 0f 00 3f 00 00 00 99 39 22"],
"settings_cup_lighting_off": ["0d 0b 90 0f 00 3f 00 00 00 91 b8 2a"],
"settings_cup_warmer_on": ["0d 0b 90 0f 00 3f 00 00 00 b1 9c 48"],
"settings_cup_warmer_off": ["0d 0b 90 0f 00 3f 00 00 00 91 b8 2a"],
"settings_energy_saving_on": ["0d 0b 90 0f 00 3f 00 00 00 91 b8 2a"],
"settings_energy_saving_off": ["0d 0b 90 0f 00 3f 00 00 00 81 aa 1b"],
"settings_beep_sound_on": ["0d 0b 90 0f 00 3f 00 00 00 91 b8 2a"],
"settings_beep_sound_off": ["0d 0b 90 0f 00 3f 00 00 00 95 f8 ae"],
"settings_show_time": ["0d 08 95 0f 00 5f 03 00 eb"],
"settings_water_hardness_1": ["0d 0b 90 0f 00 32 00 00 00 00 0a c8"],
"settings_water_hardness_2": ["0d 0b 90 0f 00 32 00 00 00 02 2a 8a"],
"settings_water_hardness_3": ["0d 0b 90 0f 00 32 00 00 00 02 2a 8a"],
"settings_water_hardness_4": ["0d 0b 90 0f 00 32 00 00 00 03 3a ab"],
"beverages_setting_a1_q20_t1": ["0d 11 83 f0 01 00 01 00 14 02 01 08 00 00 00 05 bb fd"],
"beverages_setting_a2_q20_t1": ["0d 11 83 f0 01 00 01 00 14 02 02 08 00 00 00 05 75 1d"],
"beverages_setting_a3_q20_t1": ["0d 11 83 f0 01 00 01 00 14 02 03 08 00 00 00 05 30 bd"],
"beverages_setting_a4_q20_t1": ["0d 11 83 f0 01 00 01 00 14 02 04 08 00 00 00 05 f8 fc"],
"beverages_setting_a5_q20_t1": ["0d 11 83 f0 01 00 01 00 14 02 05 08 00 00 00 05 bd 5c"],
"beverages_setting_a2_q40_t2": ["0d 11 83 f0 01 00 01 00 28 02 02 08 00 00 00 05 22 76"],
"beverage_espresso_1_a1_q20_t1": ["0d 11 83 f0 01 01 01 00 14 02 01 08 00 00 00 06 53 d7", "0d 08 83 f0 01 02 06 9d e1"],
"beverage_espresso_1_a2_q40_t2": ["0d 11 83 f0 01 01 01 00 28 02 02 08 00 00 00 06 ca 5c", "0d 08 83 f0 01 02 06 9d e1"],
"beverage_espresso_1_a3_q40_t2": ["0d 11 83 f0 01 01 01 00 28 02 03 08 00 00 00 06 8f fc", "0d 08 83 f0 01 02 06 9d e1"],
"beverage_espresso_2": ["0d 11 83 f0 01 01 01 00 28 02 03 08 01 00 00 06 f9 48", "0d 08 83 f0 01 02 06 9d e1"],
"beverage_coffee": ["0d 0f 83 f0 02 01 01 00 67 02 02 00 00 06 77 ff", "0d 08 83 f0 02 02 06 c4 b1"],
"beverage_doppio_plus": ["0d 0d 83 f0 05 01 01 00 78 00 00 06 c4 7e", "0d 08 83 f0 05 02 06 41 21"],
"beverage_steam": ["0d 0d 83 f0 11 01 09 03 84 1c 01 06 c0 7b", "0d 08 83 f0 11 02 06 de 82"],
"beverage_hot_water": ["0d 0d 83 f0 10 01 0f 00 fa 1c 01 06 04 b4", "0d 08 83 f0 10 02 06 e9 b2"],
"beverage_2_espressos": ["0d 0f 83 f0 04 01 01 00 28 02 02 00 00 06 ab 53", "0d 08 83 f0 04 02 06 76 11"],
"beverage_americano": ["0d 12 83 f0 06 01 01 00 28 02 03 0f 00 6e 00 00 06 47 8b", "0d 08 83 f0 06 02 06 18 71"],
"beverage_coffee_long": ["0d 0f 83 f0 03 01 01 00 a0 02 03 00 00 06 18 7f", "0d 08 83 f0 03 02 06 f3 81"],
NOTES:
The packets are sent by chunks (each entry in the arrays above corresponds to one chunck). For example, the turn_on commands need to send 6 times the following packet: “0d 07 84 0f 02 01 55 12”.
For the machine_status, we need to send “0d 08 95 0f 00 32 01 5d df” followed by “0d 08 95 0f 00 3f 01 2b 83”.
Explanation about the arbitrary beverage naming I am using above (ie. beverage_espresso_1_a3_q40_t2):
- a is for Aroma: 5 levels
- q is for quantity: from 20 to 120ml
- t is for temperature: 4 levels
- espresso_1 is one cup of espresso
- espresso_2 is two cups of espresso
I still need to figure all the other combinations! I am just short on time
Also, sending commands to the machine should be easy to do now. However, I am still figuring out the correct protocol that the machine is using. I am looking into decoding the responses coming from the machine. But it’s a little bit challenging, since De’longhi seems to be using a proprietary protocol. But I am working on it
I will keep you updated here once I have more news!
Cheers.
