I am trying to set the status of a contact sensor using my raspberry pi + sensor and using this framework to send message to a smartapp: https://github.com/dpjanes/iotdb-smartthings. I can get the status of the sensor but I am unsure on how to change it so it would appear open/closed.
This is what I am currently doing:
python smartthings.py --type contact --id “myid” --request contact=true
and get this back:
{‘device’: {u’id’: u’myid’,
u’label’: u’Garage Door’,
u’mqtt’: u’tcp://mqtt.iotdb.org/u//st/contact/mqttID’,
u’type’: u’contact’,
‘url’: u’https://graph.api.smartthings.com/api/smartapps/installations/id’,
u’value’: {u’contact’: False, u’timestamp’: None}},
‘request’: {‘contact’: ‘true’}}
Any advice because the status never changes?
Also if there is a easier way or alternative for using an already setup switch connected to a raspberry pi im eager to learn something
Thank you!
