Change sendcmd to send via wifi
i’m trying to send these commands via local network instead of via ST cloud. i believe i’m missing sendhubcmd, however when i change these sendcmd to sendhubcmd i get errors on execution. its a simple script that connects to another api. i can post the whole code here if someone can help. i didnt write this, just trying to hack it up for security.
the api is from alarmserver, so basically i connect to 192.168.1.x:4026/api/xxxx to send commands.
[code]/**
preferences {
input(“host”, “text”, title: “URL”, description: “The URL of your alarmserver”)
input(“port”, “text”, title: “Port”, description: “The port”)
metadata {
// Automatically generated. Make future change here.
definition (name: “DSC Alarm Stay Arm”, author: “ethomasii@gmail.com”) {
capability “Alarm”
capability “Switch”
	command "arm"
	command "disarm"
	command "stay"
	command "disarm2"
// simulator metadata
simulator {
// UI tile definitions
tiles {
	standardTile("button", "device.switch", width: 1, height: 1, canChangeIcon: true) {
		state "off", label: 'Stay Arm', action: "switch.on", icon: "st.Home.home4", backgroundColor: "#ccffcc"
		state "on", label: 'Disarm', action: "switch.off", icon: "st.Home.home4", backgroundColor: "#EE0000"
	main "button"
	details(["button"])
def sendCmd(apiCall)
httpGet(“http://${settings.host}:${settings.port}/${apiCall}”) {response →
def content = response.data
log.debug content
def arm() {
//sendCmd(“api/alarm/stayarm”)
//sendEvent(name: “button”, value: “arm”)
log.debug “Executing ‘arm’”
// TODO: handle ‘strobe’ command
sendEvent(name: “switch”, value: “on”);
def on() {
//right now do not arm or disarm…
//sendEvent(name: “button2”, value: “stay”)
log.debug “Executing ‘stay’”
// TODO: handle ‘siren’ command
def disarm() {
//sendCmd(“api/alarm/disarm”)
//sendEvent(name: “button”, value: “disarm”)
log.debug “Executing ‘disarm’”
// TODO: handle ‘both’ command
sendEvent(name: “switch”, value: “off”);
def off() {
//sendEvent(name: “button2”, value: “disarm2”)
}[/code]
