I’m writing a device type that needs to poke a very complicated XML api and I’d like to debug and code it locally (in Eclipse or else).
Now, I understand that the httpGet is ST supplied wrapper around the Java/Groovy Http class… Is there a way to debug this locally? i.e. making “httpGet” calls on my machine, inside Eclipse or else.
I don’t need to have the call emulated, I just need to figure out which type is returned… I tried it out and I can just supply a closure using “response.data.[item].each”… what’s the underlying structure? I can supply the XML in a String : I just want to figure out my algorithm to traverse the nodes in the XML file.
I think the returned response type is variable depending upon the content, but if it’s XML it’s probably a GPathResult object, resulting from parsing the XML.
You could try this:
httpGet(params) {resp->
log.debug "resp.data a GPathResult? ${resp.data instanceof groovy.util.slurpersupport.GPathResult}"
Thanks Jim the the pointer in the right direction.
You are correct, the “data” property does contain a GPathResult. I created a mock object that mimick the functionnality of the httpGet method using the Url object and convert the inputstream response into a GPathResult using XmlSlurper.
On SmartThings, I get an XmlSlurper object directly from the response’s data property… but it seems it crashes because I can’t set those properties… am I missing something of I cannot set those properties?
This is what I get : groovyx.net.http.ResponseParseException: OK @ line 115
