I’m in the process of designing our house that should break ground end of this year. It’s going through a home builder but I will do all of the low-voltage wiring, they are cool with it. House is about 3600 sq ft, two story. Here’s what I’ve got down for the basics so far. Much of this mimics my existing house, but was done over the years as needed with lots of cat5 ran under siding, through attic, etc. I want to have as much as I can think of done before the sheetrock goes up. Any ideas or criticism are welcomed!
Smartthings v2 hub. Already have it in current house, will move over to new house. Works great, no complaints.
Wall switches will be GE Z wave where needed, maybe some Z wave outlets where needed as well. I have a lot of switches in the current house that I plan to take them with me and re-install. Will have electrician pigtail a single neutral and cap it in each light switch box for future install of switches.
Smart thermostats, two zones. Currently using two nests that will probably stay at the current house. Thinking about Ecobee4?
Cat6 to rooms as needed, two runs to bedrooms, 4 runs to game room, 6-8 runs to living room, etc. Including the outside cameras, I’m quickly filling up a 48 port patch panel. Yikes! I’ll have either a single floor mount server rack or maybe split into two smaller wall mount racks to separate ethernet and whole house audio. Cable modem, router, switches, NAS box, Camera PC, etc will be in the rack as well. Coax runs may be installed in one of the racks or might do a wall mount structed wiring box next to it. Maybe this can share the same box as the alarm system? All of this is going in a large closet in my upstairs office that will have a door to access the attic and will be ventilated.
Cat6 run outside for PoE cams, looks like 8 total (standalone system, currently using Blue Iris and will most likely stay with that)
Thinking about disabling the Wi-Fi radio on my router and installing two Ubiquiti access points, one upstairs, one downstairs.
Hard wired alarm contacts at each window and door. Need guidance here, not sure what to go with. Don’t want proprietary system, ie ADT. I’ve seen ELK talked about a little? Would not mind some sort of touch screen interface for alarm and ST integration? Might be overkill…
Speaker wire to specific rooms for whole house audio. Been looking at HTD Lync system, would have about 10 zones. This would likely be future, but would probably go ahead and install the speakers in the downstairs room so I’m not fishing around in the ceilings for cables. Upstairs would have attic access to install speakers, only 2-3 rooms would get them anyways.
Future media room planned with a projector and 7.1 sound. Builder will frame it in and I’ll finish it out later. (house already over budget)
