BTF Lighting LEDs
Looking at BTF Lighting strips for an under cabinet project. Anyone have any experience with these? Out of the box says compatible with Alexa and Google Home but want to go direct (or near direct) integration with ST. Option is to just cut off the PS and controller and use Fibaro and a quality PS.
Thoughts/ Advice?
@James_Sherwood, what did you wind up doing? I’m trying to figure this one out too.
Sorry to be the bearer of bad news, but you responded to a 4-year old post. If you click the original poster’s name, you can see he last posted in June of '20–so, don’t get your hopes up he will see this.
Other members of the forum, however, may respond. Good Luck!
Thanks! I figured it was a 50/50 chance. I’m obviously new here, so can you direct me to the posts I should read to get better acquainted and avoid annoying the community with questions that have been asked 1000 times?
Welcome! :sunglasses:
SmartThings is a big complicated System and the company doesn’t really provide beginner tutorials. So you just kind of have to walk around in the dark bumping into things until you find something specific you want to research.
Assuming you do have a hub, it would probably be a good idea to start with the following. It will introduce you to a lot of the terminology and some of the basic concepts.
FAQ: I have no idea what Edge is. Is that a new developer tool? (2022)
Other than that, it’s helpful to be aware that there are FAQs for a lot of the more common questions so it’s good to skim those when you are starting to research a specific question:
There’s also a separate set of FAQs, just for questions about automations and routines:
We used to keep a “get started“ list of topics, but smartthings went through a major major architecture change in 2023, and the list has not been updated to remove obsolete threads. So I don’t know if it’s really helpful right now, but here it is. A lot of the topics are still applicable, but some of them are not. :thinking:
https://community.smartthings.com/tag/project_getstarted
Thank you for helping out!
