is definitely because the URL is wrong (port). Also, the HTTP Event Collector needs to be enabled. You do that in the Global Settings under the HTTP Event Collecter in Splunk. Have you done that?
My only concern is I am not sure where my URL for my server lies. Where can I find that information? (I am using Splunk Lite, so most of this is setup for me.)
If I am unable to get this working, can I run through teamview with you on the weekend? I am currently traveling for work and unable to download teamview.
thank you @kristerpher_hen for your assistance with @wilsonlu on this. I setup a splunk cloud instance a long time ago but quickly killed it off in favor of just building out a VM at the house with my own local splunk instance.
I agree that having a local instance is definitely easier but I’d like to hear how you guys get this setup and working and let me know if there are some changes that we’ll need to make to the code in order to accommodate future splunk cloud instances. Thanks.
Machine running OpenSuse with ports 8089 and 8088 open on the firewall.
Installed Splunk Indexer.
Then I configured your code in the SmartThings app with local IP. And it
worked. At first I got error but was able troubleshoot easily. I was
suggesting a team viewer session so I could easily go through all the
settings.
I was talking with my colleagues at work and they think the Splunk Cloud might not allow ingress of activity on a port like that… It might only allow connectivity through a specialized forwarder. If that is the case then you will need to probably build this in the house… I might hit up one of the Splunk Cloud dudes on slack today and get his opinion. I’ll let you know the outcome.
@wilsonlu you will need to call Splunk Cloud Support and ask them open the ports for you. At that point you will then be able to access your Splunk Instance!
I’m trying to use a local server, HTTPS. I have tested Splunk with a curl command which works fine, but no messages are showing up from ST. I suspect it’s a typo in the token, but without the response from Splunk, it’s hard to tell.
Let me see what I can do here with spitting out some log details. I’ll update the repo once I get it working. I too am new to groovy and everything this was definitely a hack job to get it to work. If you’re using a local server I wouldn’t bother with the HTTPS since its all internal communication. The HTTPS request was for the early days of my app before I had local hub commands working
Ok thank you to @iBeech for your example of how to return the results from the hubaction.
@halr9000 so in my reading up on how to figure out how to get the results to return with the hubaction I also discovered that for local LAN calls ST will not work with HTTPS it will only do HTTP so you’ll need to turn off the HTTPS.
Also the other item that I’ve discovered here as of lately since I recently split my whole house up into multiple vlans. ST does not know how to route off to other VLANs. i.e. All of my Kodi devices were on my media vlan and ST was still on my lan so it would not talk to Kodi anymore so I had to move ST off to my media vlan no big deal but weird. I’ll post more on this in a new thread.
So at last if you would like to go do a pull I’ve updated my github with new code that will now spit out a result in your logs that looks like this
4161b9ce-a6ab-457e-9b74-57ccb4ae786a 11:02:25 AM: debug POST /services/collector/event HTTP/1.1
Accept: */*
User-Agent: Linux UPnP/1.0 SmartThings
Authorization: Splunk YOUR TOKEN WILL SHOW UP HERE
Content-Length: 597
HOST: YOUR IP ADDRESS WILL SHOW UP HERE
Content-Type: application/json
Accept-Encoding: gzip,deflate
{"event":{"date":"Mon Nov 28 18:02:25 UTC 2016","name":"temperature","displayName":"West Side Motion","device":"West Side Motion","deviceId":"5df62ea8-d840-4ce8-9afb-a9cf0f9f2259","value":"44.4","isStateChange":"true","id":"d198ad10-b594-11e6-bfc4-121da09e2cea","description":"zw device: 2A, command: 3105, payload: 01 2A 01 BC","descriptionText":"West Side Motion temperature is 44.4°F","installedSmartAppId":"null","isoDate":"2016-11-28T18:02:25.743Z","isDigital":"false","isPhysical":"false","location":"Home","locationId":"652fa5ce-fb35-430e-ad5a-0aedfcf30dd2","unit":"F","source":"DEVICE",}}
Some day I’ll figure out how to disable the use ssl and stuff if the use internal is set to true but thats for another day.
Ok so while my new code looked like it was working and I truly thought it was. Turns out it does spit out the results fine but it never actually makes the call back to splunk. So its more like a simulator of this is what I’m going to do but not actually do it. I’m working on trying to figure out what changes I need to make to the code to make this work. Will update once I am ready. Thanks.
Hmm, I am getting full debug messages now, but no events in Splunk. Wondering if I have a networking issue like yours. Ahh–it is indeed on a different subnet. Fingers crossed…
So in my case I’m using PFSense as my home firewall.
So what I did was setup HAProxy on PFSense and told it to proxy back to splunk. I then also told it to listen on the address of the subnet that ST was listening on. Lol its a stupid hack/work around but it gets the job done. Really wish that ST just knew hey here is your gateway now just let the router do what its supposed to do.
