Best SmartApp for Complex "follow me" Dimming Setups?
I think I’ve got this worked out for you. I used the Big Switch app as a model. That app allows a switch to follow on and off commands, only on commands, only off, etc… In this new version, I similarly separated out the dimmer slaves from the on/off, only on and only off slaves. It means for a typical dim with me, you need to include the slaves twice; but there’s a lot more flexibility now.
For your scenario, you’ll need to include the dining table lights in two sections: 1) The “on, but not off” (Slave On). 2) The appropriate dimming offset section. I think this will work nicely. Not a big fan of the UI, but it was a lot easier to code than providing groups and then letting the user select which commands to follow.
 *  Dim With Me - plus offset
 *  Original Author: todd@wackford.net
 *  Date: 2013-11-12
 *  App Name:   Dim With Me plus Offset
 *  Author:     Todd Wackford
 *        twack@wackware.net
 *  Date:     2013-11-12
 *  Version:     0.2
 *  Use this program with a virtual dimmer as the master for best results.
 *  This app lets the user select from a list of dimmers to act as a triggering
 *  master for other dimmers or regular switches. Regular switches come on
 *  anytime the master dimmer is on or dimmer level is set to more than 0%.
 *  of the master dimmer.
 *                                Changes
 *  Change 1:    2014-10-22 (wackford)
 *        Fixed bug in setlevelwhen on/off was coming in
 *  Change 2:    2014-11-01 (wackford)
 *        added subscription to switch.level event. Shouldn't change much
 *        but some devices only sending level event and not setLevel.
 *  Change 3:   2015-05-05 (sticks18)
 *              added ability to offset slave dimmers in case different lights
 *              dim differently or have varying lumen output.
  Other Info:    Special thanks to Danny Kleinman at ST for helping me get the
                state stuff figured out. The Android state filtering had me
                stumped.
// Automatically generated. Make future change here.
definition(
    name: "Dim With Me plus Offset",
    namespace: "wackware",
    author: "todd@wackford.net",
    description: "Follows the dimmer level of another dimmer",
    category: "My Apps",
    iconUrl: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience.png",
    iconX2Url: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience%402x.png"
preferences {
    page(name: "selectMaster", title: "Choose a Master, then choose Slaves to follow...", install: true, uninstall: true) {
        section("When this...") {
            input "masters", "capability.switchLevel",
                multiple: false,
                title: "Master Dimmer Switch...",
                required: true
        section("Then these will follow on and off commands...") {
            input "slaves2", "capability.switch",
                multiple: true,
                title: "Slave On/Off Switch(es)...",
                required: false
        section("Then these will follow on commands, but not off...") {
            input "slaves3", "capability.switch",
                multiple: true,
                title: "Slave On Switch(es)...",
                required: false
        section("Then these will follow off commands, but not on...") {
            input "slaves4", "capability.switch",
                multiple: true,
                title: "Slave Off Switch(es)...",
                required: false
        section("And these will follow with the same dimming level, but not on or off...") {
            input "slaves", "capability.switchLevel",
                multiple: true,
                title: "Slave Dimmer Switch(es)...",
                required: false
        section("Slaves with dimming offset (will not follow on/off commands, please include above if desired)...") {
            href "addOffset", title:"Additive Offset (Slave = Master Level + Offset)"
            href "minusOffset", title: "Negative Offset (Slave = Master Level - Offset)"
            href "ratioOffset", title: "Ratio Offset (Slave X% of Master Level)"
        section("Name and Mode...") {
            label title: "Assign a name", required: false
            mode title: "Set for specific mode(s)", required: false
    page(name: "addOffset", title: "addOffset")
    page(name: "minusOffset", title: "minusOffset")
    page(name: "ratioOffset", title: "ratioOffset")
def addOffset() {
    dynamicPage(name: "addOffset", title: "Select Additive Offset Slave Dimmers...", install:false, uninstall: false) {
        section("Additive Offset Group 1") {
            input "slavesAdd1", "capability.switchLevel", title: "Slave Dimmers...", multiple: true, required: false
            input "levelAdd1", "number", title: "Level Offset (number to be added to master level)", required: false
        section("Additive Offset Group 2") {
            input "slavesAdd2", "capability.switchLevel", title: "Slave Dimmers...", multiple: true, required: false
            input "levelAdd2", "number", title: "Level Offset (number to be added to master level)", required: false
def minusOffset() {
    dynamicPage(name: "minusOffset", title: "Select Negative Offset Slave Dimmers...", install:false, uninstall: false) {
        section("Negative Offset Group 1") {
            input "slavesMin1", "capability.switchLevel", title: "Slave Dimmers...", multiple: true, required: false
            input "levelMin1", "number", title: "Level Offset (number to be subtracted from master level)", required: false
        section("Negative Offset Group 2") {
            input "slavesMin2", "capability.switchLevel", title: "Slave Dimmers...", multiple: true, required: false
            input "levelMin2", "number", title: "Level Offset (number to be subtracted from master level)", required: false
def ratioOffset() {
    dynamicPage(name: "ratioOffset", title: "Select Ratio Offset Slave Dimmers...", install:false, uninstall: false) {
        section("Ratio Offset Group 1") {
            input "slavesRatio1", "capability.switchLevel", title: "Slave Dimmers...", multiple: true, required: false
            input "levelRatio1", "number", title: "X% of Master Level (ie: 10 = 0.10 * Master Level, 110 = 1.10 * Master Level)", required: false
        section("Ratio Offset Group 2") {
            input "slavesRatio2", "capability.switchLevel", title: "Slave Dimmers...", multiple: true, required: false
            input "levelRatio2", "number", title: "X% of Master Level (ie: 10 = 0.10 * Master Level, 110 = 1.10 * Master Level)", required: false
def installed()
    subscribe(masters, "switch.on", switchOnHandler)
    subscribe(masters, "switch.off", switchOffHandler)
    subscribe(masters, "switch.setLevel", switchSetLevelHandler)
    subscribe(masters, "switch", switchSetLevelHandler)
    subscribe(masters, "level", switchSetLevelHandler)
def updated()
    unsubscribe()
    log.info "subscribed to all of switches events"
def switchSetLevelHandler(evt)
    if ((evt.value == "on") || (evt.value == "off" ))
        return
    def level = evt.value.toFloat()
    level = level.toInteger()
    log.info "switchSetLevelHandler Event: ${level}"
    if (levelAdd1) {
        def lvlAdd1 = level + levelAdd1
        lvlAdd1 = lvlAdd1.toInteger()
        if (lvlAdd1 > 100) {lvlAdd1 = 100}
        if ((lvlAdd1 < 1) && (level > 0)) {lvlAdd1 = 1}
        log.info "switchSetLevelHandler Add 1 Offset Event: ${lvlAdd1}"
        slavesAdd1?.setLevel(lvlAdd1)
    if (levelAdd2) {
        def lvlAdd2 = level + levelAdd2
        lvlAdd2 = lvlAdd2.toInteger()
        if (lvlAdd2 > 100) {lvlAdd2 = 100}
        if ((lvlAdd2 < 1) && (level > 0)) {lvlAdd2 = 1}
        log.info "switchSetLevelHandler Add 2 Offset Event: ${lvlAdd2}"
        slavesAdd2?.setLevel(lvlAdd2)
    if (levelMin1) {
        def lvlMin1 = level - levelMin1
        lvlMin1 = lvlMin1.toInteger()
        if (lvlMin1 > 100) {lvlMin1 = 100}
        if ((lvlMin1 < 1) && (level > 0)) {lvlMin1 = 1}
        log.info "switchSetLevelHandler Minus 1 Offset Event: ${lvlMin1}"
        slavesMin1?.setLevel(lvlMin1)
    if (levelMin2) {
        def lvlMin2 = level - levelMin2
        lvlMin2 = lvlMin2.toInteger()
        if (lvlMin2 > 100) {lvlMin2 = 100}
        if ((lvlMin2 < 1) && (level > 0)) {lvlMin2 = 1}
        log.info "switchSetLevelHandler Minus 2 Offset Event: ${lvlMin2}"
        slavesMin2?.setLevel(lvlMin2)
    if (levelRatio1) {
        def lvlRatio1 = levelRatio1.toFloat()
        lvlRatio1 = lvlRatio1 / 100
        lvlRatio1 = lvlRatio1 * level
        lvlRatio1 = lvlRatio1.toInteger()
        if (lvlRatio1 > 100) {lvlRatio1 = 100}
        if ((lvlRatio1 < 1) && (level > 0)) {lvlRatio1 = 1}
        log.info "switchSetLevelHandler Ratio 1 Offset Event: ${lvlRatio1}"
        slavesRatio1?.setLevel(lvlRatio1)
    if (levelRatio2) {
        def lvlRatio2 = levelRatio2.toFloat()
        lvlRatio2 = lvlRatio2 / 100
        lvlRatio2 = lvlRatio2 * level
        lvlRatio2 = lvlRatio2.toInteger()
        if (lvlRatio2 > 100) {lvlRatio2 = 100}
        if ((lvlRatio2 < 1) && (level > 0)) {lvlRatio2 = 1}
        log.info "switchSetLevelHandler Ratio 2 Offset Event: ${lvlRatio2}"
        slavesRatio2?.setLevel(lvlRatio2)
    slaves?.setLevel(level)
def switchOffHandler(evt) {
    log.info "switchoffHandler Event: ${evt.value}"
    slaves4?.off()
    slaves2?.off()
def switchOnHandler(evt) {
    log.info "switchOnHandler Event: ${evt.value}"
    def dimmerValue = masters.latestValue("level") //can be turned on by setting the level
    slaves3?.on()
    slaves2?.on()
Looks great! Especially like the ratio dimming section.
