Best inexpensive door lock?
Are you looking to retrofit your existing lock? If you want to stay under 60 or $70, there are a couple of options.
If so, @johnconstantelo Took a magnetic sensor and stuck it on the deadbolt on the inside so that it would trigger if the lock was opened. That could be quite inexpensive relative to an actual smart lock.
Another option would be to use an electric strike. But that would be replacing your existing lock.
You can also look at the quick browse projects list for lock projects and see if there’s anything there you could use:
http://thingsthataresmart.wiki/index.php?title=How_to_Quick_Browse_the_Community-Created_SmartApps_Forum_Section
