Best hard wired smoke / CO alarm & monitoring for Sump Pump
A couple of thoughts:
If you decide to use a relay and contract sensor to connect your hard wired alarms, here is a great DTH:
There is also the option to use a sound sensor to detect alerts:
For the sump pump you may want to look at this:
https://www.amazon.com/Aeotec-Aeon-Labs-DSB45-Sensor/dp/B00H3TJ3P4/ref=sr_1_1?s=hi&ie=UTF8&qid=1495032668&sr=1-1&keywords=aeon+water+sensor
You can put the sensor at the same level where your sump pump starts. This way you would get an alert every time. If you put it slightly higher, you would get alerts only when the sump pump fails.
