I have an automation set for humidity that will not run unless manually turned on to trigger setpoint change. Example humidifier turns off when leaving home. Upon returning automation is set to run when humidity is less than 40 percent. Will not turn on even though have check sensor has since reported. If turn on will turn off again at low/high setpoin. Is there a way to check everyso often if the statement is true to trigger without crossing threshold of automation? Thanks
Related topics
Topic | Replies | Views | Activity | |
Automations not working | 4 | 687 | August 20, 2020 | |
Automations & Weather not working | 26 | 1732 | October 23, 2021 | |
Request for Help - Run A/C If Humidity is Too High | 3 | 1354 | January 11, 2016 | |
Help needed with automation Nest + Classic app | 0 | 378 | December 16, 2018 | |
Specific automations (involving water/smoke) not working | 4 | 374 | October 25, 2021 |
