Hello all. This is kind of a crazy set of questions here.
I know that I can use association to have one Evolve Accessory Dimmer controlling two different Evolve Load Bearing Dimmers. Can two different Evolve Accessory Dimmers control one Evolve Load Bearing Dimmer?
Assuming the answer to the first question is “yes,” should you be able to associate an Evolve (or Linear) Accessory Dimmer with an Aeon Micro In Wall Dimmer? Or because they are two different companies, they won’t associate? Ultimately I want to know if I can use a toggle dimmer (non load bearing) to control a micro in walll dimmer (load bearing) through association.
