Ok, I understand it is a build in security feature, however, in my case I have a front Gate and there is no way someone from the street can enter the house by talking to Alexa through door. At the same time, once I open a gate to my buddies (automating it via push button), I would like to simply tell Alexa to open the front door so I don’t have to walk down from the one end of the house to another when i am busy at the kitchen.
How do I do that?
There were some responses in your first post back in December. Did none of them work? I believe the virtual switch is one option to consider.
Yeah, none of the responses I got back about a year ago worked. I was wondering if there are any new or updated smart apps to make it work.
While it is a ‘big’ install Ask Alexa can do this, but it would fundamentally change how you use alexa (like putting 'ask Smart thing" in front of the command.
Thank you Nezmo. I am still learning new Alexa app. I can’t even find “Smar tHome” under setting options anymore. Where is Smart Home on the new app?
Here you go:
Then once you choose locks and the specific lock device click the three dots to get to settings:
Thank you. Will try it.
