APsystems YC600 Microinverter monitored by the Samsung hub
Hello All,
I have an Samsung smartthing hub at home and I’m planning to install solar panels for auto consume energy at home.
I found that the APSystem YC600 Microinverter has Zigbee communication for Energy Monitor and Analysis using the APSystem Energy Communication Unit but not sure if it works with the ST hub.
I tried to find something in the forum, but I haven’t found anything similar.
I would like to understand if someone is using this Microinverter and if managed monitor the microinverter using the Samsung hub .
Thank you very much
Regards
José Guerreiro
Unfortunately, it doesn’t use the same zigbee profile that smartthings uses. See the following (the topic title is a clickable link)
:frowning:
Thank you!
Regards
José Guerreiro
Do you know wich profile APSystem use?
Hi Marcus,
I decided to put on hold this solution.
Thank you
Regards
José Guerreiro
APSystem answer me:
“Our Zigbee profile is proprietary. Designed for our system only and the specific specs are not public. QS1 zigbee is non-standard Zigbee profile.”
Thanks for sharing!
