I am wanting an app that can turn selected lights on for a random amount of time and then turn them off.
The idea being, if in Away mode (and after a certain time of day or sunset) then you can choose certain lights to turn on and off making the house look lived in.
I guess you might need other values too - i.e. how often during the night should the lights turn on etc…
Is there a random function that is available and is something like this app possible?
There used to be. I can’t find it now. It was under security. It was pretty cool. Instead of random on/off and duration, it used actual activity from a random day in the past. I’ll see if I can find the app name and code.
* Smarter Home Light Simulator
* Author: Austin Fonacier
* Twitter: @austinrfnd
* Github: http://github.com/austinrfnd
preferences {
section("Light switches to turn on/off"){
input "switches", "capability.switch", title: "Switches", multiple: true, required: true
section("How often to cycle the lights"){
input "frequency_minutes", "number", title: "Minutes?"
section("Number of actives lights at any given time"){
input "number_of_active_lights", "number", title: "Number of active lights"
def installed() {
scheduleCheck()
def updated() {
unsubscribe()
unschedule()
scheduleCheck()
// We want to turn off all the lights
// Then we want to take a random set of lights and turn those on
// Then run it again when the frequency demands it
def scheduleCheck() {
// turn off all the switches
switches.off()
// grab a random switch
def random = new Random()
def inactive_switches = switches
for (int i = 0 ; i < number_of_active_lights ; i++) {
// if there are no inactive switches to turn on then let's break
if (inactive_switches.size() == 0){
break
// grab a random switch and turn it on
def random_int = random.nextInt(inactive_switches.size())
inactive_switches[random_int].on()
// then remove that switch from the pool off switches that can be turned on
inactive_switches.remove(random_int)
// re-run again when the frequency demands it
runIn(frequency_minutes * 60, scheduleCheck)
I think the addition of turning the lights on for a random time and only when in certain modes would perfect this.
I may even be able to add those features
