Anything to trigger my 433Mhz rolling code triggered electric gates?
But what can I get that’ll record the 314mhz this remote is spitting out and then repeat it to open the gate triggered by an arduino?
I think I might try and put an RP-SMA connector on this remote control board and see what that does. I suppose range isn’t “quite” as important now if I could get an arduino to “push” the button for me and then link that up to the SmartThings shield id be winning, I can put it fairly close to the gate and have the module connect via zigbee. I think even the standard remote would work from the position id be able to mount it. Though having 5v running to the Arduino and then a separate 12v in whats left in the remote is a bit messy.
