rteeples
(Ryan Teeples)
March 16, 2018, 5:27pm
1
Anyone tried to make this work with Smartthings?
Start to get a smart switch,living in a joyful home. Due to the glue job done not well in a production rush on February in 2018,the glass panel of the switch may fall out. We will refund you immediate ...
If you’re asking about integration options, this is one of many inexpensive Wi-Fi switches which uses the tuya “smart life” app. See the FAQ (this is a clickable link)
That switch uses the smartlife app. There are many other inexpensive Chinese Wi-Fi devices that also use the same app.
In May2020, SmartLife dropped their IFTTT channel due to increasing costs. Paul Hibbard, a tech blogger, says you can try the “brilliant smart“ app from Australia instead, as it has its own Ifttt channel. That company told him they recently renewed with Ifttt, so he says it should be good for at least a year. However, it’s always possible that the company will shut this down for brands other than their own if it starts costing too much money.
To use the IFTTT method:
Create a virtual switch in smartthings to act as a proxy for the Wi-Fi device. You need one virtual switch for each Wi-Fi device.
Create four IFTTT applets for each Wi-Fi device. one to turn the …
If you’re asking about build quality for that particular brand, see the Amazon reviews.
