I currently use an iTach WF2IR to control my home theater using the Roomie Remote app. Does anyone know if ST can communicate with the iTach?
thanks
thanks
yup. check this out.
Thanks for the post. I am not that familiar with the code, is it possible to get some more details on how to implement this? Thanks
When you say ‘code’, what do you mean? The command string you send to the iTach, or the SmartThings app call to send it?
both, not really sure where to start
Do you already have an iTach? What are you using it with now?
I currently have a wifi2ir unit that I use for my home theater (roomie remote app) I have recently purchased a somfy roller shade motor that uses ir and would like to have smartthings control the shade.
Well roomie most likely has component libraries of IR commands that you just assign to buttons, but the native command actually being sent to the iTach looks something like this:
sendir,1:3,1,39000,3,1,95,23,48,23,48,23,48,23,48,23,23,23,48,23,23,23,23,23,48,23,23,23,48,23,48,23,23,23,48,23,23,23,23,23,23,23,48,23,48,23,48,512\r
The above command is a discreet ‘off’ command for a Sony BluRay Player. You can find these commands online in various formats, and GC has a conversion app to convert raw HEX to native GC commands. Also, your iTach has the ability to record these codes directly from your IR remotes using the iLearn app they provide.
Once you know the codes you want to send, you send it from a SmartApp with the send hub command I previously described here.
I did need to use the learning feature in the roomie remote app I order to get it to work but I am familiar with the ilearn app as well. When I create a new smart app I simply copy and paste the code from the link you provided and modify with my hex code?
Sorry for all the questions, I am pumped this can actually work.
Yes. The only thing you’ll need to convert to hex is the IP address of your iTach.
Thanks for your help, I will give it a shot tonight.
So I created a new app and added the code from your link above and I am receiving a java error. see code below
definition(
namespace: “”,
author: “Cass Mieczakowski”,
desription: “Shade”,
category: “My Apps”,
iconUrl: “https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience.png”,
iconX2Url: “https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience@2x.png”)
sendHubCommand(new physicalgraph.device.HubAction("""$sendir,1:3,1,39000,3,1,95,23,48,23,48,23,48,23,48,23,23,23,48,23,23,23,23,23,48,23,23,23,48,23,48,23,23,23,48,23,23,23,23,23,23,23,48,23,48,23,48,512\r\n""", physicalgraph.device.Protocol.LAN, “${0x0A000114}”))
It would appear this is your first crack at a SmartApp. While you almost got the sendhub command right, a single command does not make a SmartApp. You’ll need to define input(s) and an event handler for it to be able to do anything. Have a look at some of the examples in the IDE.
Now for the sendhub command… assuming your iTach’s ip address is 10.0.1.20
def deviceNetworkId = " 0A000114:1386"
def theCom = "sendir,1:3,1,39000,3,1,95,23,48,23,48,23,48,23,48,23,23,23,48,23,23,23,23,23,48,23,23,23,48,23,48,23,23,23,48,23,23,23,23,23,23,23,48,23,48,23,48,512\r"
sendHubCommand(new physicalgraph.device.HubAction("""$theCom\r\n""", physicalgraph.device.Protocol.LAN, "${deviceNetworkId}"))
I have only modified existing smart apps never from scratch. I am having a hard time building this thing.
I am stuck because there is not an actual “thing” that is being used.
Right. It is a command you would put in an event handler, that would be triggered by a device or schedule.
Sorry to keep bugging you.
I have made some progress but have received an error with the sendhubcommand
preferences {
section(“When it gets dark”) {
input “luxSensor”, “capability.illuminanceMeasurement”, title: “At which Lux sensor?”, multi: false, required: true
input “luxLevel”, “number”, title: “Darkness Lux level?”, default: “400”
def installed() {
log.debug “Installed with settings: ${settings}”
initialize()
def updated() {
log.debug “Updated with settings: ${settings}”
unsubscribe()
// unschedule()
initialize()
def initialize() {
log.debug “Initializing - subscribing to $luxSensor”
subscribe(luxSensor, "illuminance", eHandler)
// subscribe(catDoor, “contact”, eHandler)
state.lastStatus = "unknown"
def theCom = “sendir,1:3,1,39000,3,1,95,23,48,23,48,23,48,23,48,23,23,23,48,23,23,23,23,23,48,23,23,23,48,23,48,23,23,23,48,23,23,23,23,23,23,23,48,23,48,23,48,512\r”
sendHubCommand(new physicalgraph.device.HubAction("""theCom\r\n""", physicalgraph.device.Protocol.LAN, "{deviceNetworkId}"))
Again, the send hub command (and the defs supporting it) need to go into an event handler…
def eHandler(evt) {
log.debug "Sensor says ${evt.value}"
if (evt.value <= luxLevel) {
def deviceNetworkId = "0A000114:1386"
I have the code working now and have the actual IR codes which i pulled from the iLearn app and it is not working. How does the code tell the iTach which IR blaster port to use since there are 3?
