I’m having this issue too.
Also none of my notifications are coming through on Android until I leave my geofence. iOS are coming through fine. Anyone else having an issue with notifications?
I just wanted to chime in here and state that everything has been working perfectly for me with the new app.
I love how quick it loads everything now and the widget is quite useful! Hopefully it keeps improving like this!
What “widget” is everyone talking about?
there’s a hello home action widget, have a look in your android widgets…
I have seen it. Never figured out what it was for, so I have ignored it.
Just want to follow up on a few of the reported issues and to let you know that we have bugs filed, and will address them.
params
when getting parameters from an href input element in Android. This should be the same as iOS and we will correct this.Tagging @kris so he can keep abreast of these issues
@Jim, When a smart app has dynamic pages and inputs with defaults, they are not instantiated. This is pretty serious…
@Jim, This always fails when saving a SmartApp in the IDE
def title = "${location?.name}
java.lang.NullPointerException: Cannot get property ‘name’ on null object.
@625alex is this an issue observed with the Android update? Can you post a code snippet? (the only thing I found in this thread about dynamic preferences was @Mike_Maxwell’s reported issue about params from an href input not working correctly)
https://github.com/625alex/ActiON-Dashboard/blob/master/app-v5/ActiON5SmartApp.groovy#L217
Any of the 4 inputs in this block are null unless you step into that dynamic page. I believe this used to instantiate defaults prior to update last week.
I can’t reproduce this in my simple case - this works for me:
def installed() {log.debug "location?.name"}
Is there some other context that this is failing in?
you even removed the post from the blog lol look like the bugs are real, i havent had any luckily
Just wanted to say things have been pretty smooth for me. I have several custom device types and smart apps both made by others and myself and haven’t had any new issues. Presence still seems pretty broken, working fine for a couple days then refusing to work at all while other apps/integrations still work fine. I’ve reverted back to Life360 integration for presence instead of the built in native stuff. I had hoped 1.7.x had addressed some of it but it looks like they had/have bigger fish to fry.
Not singling any issue out in particular and heck, maybe none of them even fall into this category, but as a developer in my day job, I want to point out that just because something “works” doesn’t mean it was done the correct way previously. Just something to think about. When writing good code, a developer shouldn’t write to working, they should write to correct/efficient/consistent/etc. I’ve seen hacky code made all too often then ends up being broken in an update and the hacky developer blames the update instead of themselves
Jim, refer to this minimalist sample:
https://github.com/625alex/SmartThings/blob/master/apps/bugger.groovy
location?.name
fails when saving a smart app. Lines 27-29.
All of inputs on lines 36-39 are not initialized with the default value unless I step into that dynamic page.
Thanks for the code example, that should help reproduce it.
I think this is a good opportunity for @kris to jump in and try and reproduce and help
Jim, the bug about app label defaulting to “Tap to set” is not on this list…
@Jim, https://github.com/625alex/SmartThings/blob/master/apps/bugger2.groovy demonstrates another bug:
groovy.lang.MissingMethodException: No signature of method: java.lang.String.refresh() is applicable for argument types: () values: [] Possible solutions: reverse(), reverse(), every(), every(groovy.lang.Closure), length(), grep() @ line 74
This only happens when the input for weather tile is inside a dynamic page.
Note that the system.out for weather is not what it should be. Should display device name, not ID.
initialized with settings: [weather:[7ee73fe9-5fdc-4523-894d-d0488de66cb0]]
There was no issue running this code last week.
edit: basically weather device is cast to String when input sits in a dynamic page. Was the weather tile updated recently?
Hey @625alex, If you remove the “.name” property you should be returned the name by default.
label title: "Title", required: false, defaultValue: "${location != null ? location : 'none'}"
I’m not seeing this issue on Android. Please let me know if you’re still seeing it.
