Not that you need this, but you might be interested in this DTH for the range extender. This will better notify you if the extender is unreachable. The default Z-Wave Thing expects on/off messages. It won’t fix mesh issues, but it may be helpful.
One of the things that always bothered me with the Iris plug in module is the generic Z-Wave device or switch DTHs when all I wanted was a repeater. This shows a simple interface of online/offline and works with Health Check.
Features
Checks connectivity every 15 minutes
Only shows messages in Recently tab on status change or manual refresh (NOTE: a manual refresh will temporarily remove the health check flag if offline)
Reports after two failed attempts
No events after offline detected to force App Health Check to show correctly (will take about 35 extra minutes)
Current Version: 2.00a
NOTE: If you upgrade to 2.00 or above from an older version, you must press ‘Force Reconfigure’ in the app. If you do not do this step, the DTH will not work correctly.
The code can be pulled from my…
