Hello,
How do you add a pause BETWEEN actions in core pistons.
In my specific case, My piston monitors 3 different conditions in my garage. When all three are ‘true’ my THEN ‘Action’ turns a momentary switch on which closes the garage door. I can do this part easily, Then I want to know the state of the door after 10 seconds when the door has had a chance to close (or fail in which case it would stay open). How do add a 20 second delay between actions.
Here’s my example:
IF
-> Garage door contact is open
AND
-> Garage door contact temperature is below 32 degrees
AND
-> No Motion has been sensed in the garage for 15 minutes
THEN
-> Turn on Garage Closer (remember this takes 10 seconds or so)
-> Wait 15 seconds
-> Send ‘Failure’ SMS notification if contact is ‘OPEN’
Now…I have more to it but this is where it fails- When the 3 triggers are ‘true’ the ‘Action’ of closing the door is triggered. WITHIN A COUPLE SECONDS I get a ‘failure’ SMS notification. Obviously, the piston is not waiting 15 seconds to check the state of the contact. It is my belief that piston is executing all 3 actions almost simultaneously.
What I want to do with my ‘THEN’ is this:
THEN
–> Turn on garage closer
THEN
–> Wait 15 Seconds
THEN
–> Send SMS (based on the condition of the contact sensor AFTER 15 seconds has elapsed.
Again, I want to add a ‘wait’ action BETWEEN my actions… I think I want an ‘If-Then-Then if’ piston. Am I going about this wrong? My other thought is that my ‘ACTION’ could be a ‘follow up’ piston or another ‘If-Then’ piston that would get triggered. Thoughts?
Thanks - Jim
