I’d look to handling this in the code of the app rather than in the devise type.
What I would look at doing is subscribing to when the sensor is opened and closed. When it’s opened use change a state variable to false, and then when close run a procedure in a minute to change the state.
Something like this:
def doorSensorOpen(evt) {
state.doorClosed = false
When the door opens, we change the state variable to false.
def doorSensorsClose(evt) {
runIn(60, closeState)
def closeState() {
state.doorClosed = true
What this does is when the door closes, it schedule the ‘closeState’ procedure to run in 60 seconds. This gives a 1 minute for the accelerator time to stop moving.
Then in your procedure where you run the actions when acceleration happens, put in a conditional:
def accelerationCheck {
if (state.doorClosed = true) {
Insert you code to do stuff here
That way you need acceleration AND the variable needs to say closed. And that won’t say closed until the door has been closed for at least a minute.
