Activate LIFX Scenes with ST
Is there a native way to activate a LIFX scene in ST, say through SmartLighting? I know webCoRE has this functionality, and I’m using it. I’m just curious to see if there’s a more straightforward way to accomplish it. Thanks!
That’s as straight forward as it is going to get.
I’m assuming you are using the method from the wiki:
Outside of webCoRE allowing you to directly integrate with LIFX, Smart Lighting, Routines or any other automation (not directly) will not allow you to do anything like this. The only other way I can see you doing this is via IFTTT applets (which I don’t recommend from a performance standpoint - the delay will be signicantly longer) where you have the Trigger service as SmartThings and something is switched on or off and then your Action Service is LIFX and you Activate scene. :slight_smile:
Yep. That’s what I’m doing. Though, I apparently wasn’t typing in the right stuff in the search because I didn’t see that post. Thanks for the info!
