Having a Galaxy phone means a lot in this case, because there are features available for Galaxy devices which are not available to other brands. Such as Bixby routines. ![]()
I’m not 100% sure, but my understanding is that you should just be able to set up a Bixby routine (not a SmartThings routine) to do this.
NFC tags are one of the standard Bixby routine triggers:
You can find some discussion in the following thread:
Samsung Bixby Modes and Routines to trigger Smartthings?
Anyway, someone else will have to confirm, but that’s what I’d research next in your setup. ![]()
Again, this method will only work on a Galaxy phone. For other android devices or iPhones you’d need to start looking at other methods.
