Accès Token expie at 24 hours, can I change the duration?
Hello,
I using the Access token to connect Smart Things to Home Assistant and is not posible to maintain it because the access key expire after 24 hour. how can I set to more time?
you can’t… it is set at 24 hours
The developers at Home Assistant are aware of the new limitations and working on a fix.
Thanks.
I hope that the fix get to production soon!
And yet another reason that I made the right decision to move to HomeAssistant and stop buying zwave.
