bravenel
(Bruce)
September 14, 2015, 3:02am
20
Light Power Allowance is missing also. The other missing feature is to select how many minutes after motion stops to turn something off. There is no input for minutes in that case in Smart Lights. That’s an omission that should be fixed. I would assume that turn off after some time missing is an oversight, and they should fix that also.
I just wrote two very small apps to do these two functions:
For Turn off after motion stops:
* Turn off after motion stops
* Copyright 2015 Bruce Ravenel
definition(
name: "Turn off after motion stops",
namespace: "bravenel",
author: "Bruce Ravenel",
description: "Turn some switches off some minutes after motion stops",
This file has been truncated. show original
For Turn off after some minutes:
* Turn off after some minutes
definition(
name: "Turn off after some minutes",
description: "Turn switches off after some number of minutes with restriction options",
