Is there a zigbee watering system that is fully compatible with smartthings/aeotec hub?
Hi,
The list on the App shows a system by Spruce. It requires their own hub to work with Smarthings.
Good Luck,
Paul
Hi, do you use the Spruce yourself?
Hi @hansstobbe2812 , Spruce used to be fully compatible with SmartThings back in the Groovy DTH and SmartApp days, but not anymore since ST’s platform change and the move to edge drivers. The moisture sensor may still work, but I can’t confirm because all mine eventually died.
Also, I don’t believe you can even buy their stuff anymore.
