You’ll probably want to stay away from an “app”
A device type will be more reliable as far as timing goes. A few seconds different on a car starter can mean the difference between a working starter and a blown starter motor.
You can use the momentary device type for the MimoLite and just extend the delay between to 3(ish) seconds instead of the .5 seconds it currently is set at.
Something like this maybe?
* SmartSense Virtual Momentary Contact Switch
* Author: SmartThings
* Date: 2013-03-07
metadata {
// Automatically generated. Make future change here.
definition (name: "Z-Wave Virtual Momentary Contact Switch", namespace: "smartthings", author: "SmartThings") {
capability "Actuator"
capability "Switch"
capability "Refresh"
capability "Momentary"
capability "Sensor"
capability "Relay Switch"
// simulator metadata
simulator {
status "on": "command: 2003, payload: FF"
status "off": "command: 2003, payload: 00"
// reply messages
reply "2001FF,2502,delay 2000,200100,2502": "command: 2503, payload: FF"
reply "200100,2502": "command: 2503, payload: 00"
// tile definitions
tiles {
standardTile("switch", "device.switch", width: 2, height: 2, canChangeIcon: true) {
state "off", label: '${name}', action: "momentary.push", icon: "st.switches.switch.off", backgroundColor: "#ffffff"
state "on", label: '${name}', action: "switch.off", icon: "st.switches.switch.on", backgroundColor: "#79b821"
standardTile("refresh", "device.switch", inactiveLabel: false, decoration: "flat") {
state "default", label:'', action:"refresh.refresh", icon:"st.secondary.refresh"
main "switch"
details(["switch","refresh"])
def result = null
def cmd = zwave.parse(description, [0x20: 1])
if (cmd) {
result = createEvent(zwaveEvent(cmd))
log.debug "Parse returned ${result?.descriptionText}"
return result
def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicReport cmd) {
[name: "switch", value: cmd.value ? "on" : "off", type: "physical"]
def zwaveEvent(physicalgraph.zwave.commands.switchbinaryv1.SwitchBinaryReport cmd) {
[name: "switch", value: cmd.value ? "on" : "off", type: "digital"]
def zwaveEvent(physicalgraph.zwave.commands.manufacturerspecificv2.ManufacturerSpecificReport cmd) {
if (state.manufacturer != cmd.manufacturerName) {
updateDataValue("manufacturer", cmd.manufacturerName)
final relays = [
[manufacturerId:0x0113, productTypeId: 0x5246, productId: 0x3133, productName: "Evolve LFM-20"],
[manufacturerId:0x5254, productTypeId: 0x8000, productId: 0x0002, productName: "Remotec ZFM-80"]
def productName = null
for (it in relays) {
if (it.manufacturerId == cmd.manufacturerId && it.productTypeId == cmd.productTypeId && it.productId == cmd.productId) {
productName = it.productName
break
if (productName) {
log.debug "Relay found: $productName"
updateDataValue("productName", productName)
[name: "manufacturer", value: cmd.manufacturerName]
// Handles all Z-Wave commands we aren't interested in
def push() {
def cmds = [
zwave.basicV1.basicSet(value: 0xFF).format(),
zwave.switchBinaryV1.switchBinaryGet().format(),
"delay 3000",
zwave.basicV1.basicSet(value: 0x00).format(),
def on() {
push()
def off() {
def refresh() {
delayBetween([
zwave.manufacturerSpecificV1.manufacturerSpecificGet().format()
def on() {
push()
def off() {
def poll() {
def refresh() {
