Smartthings doesn’t give us the tools to do a full zigbee map. You can see the most recently used route in the ID E, which physically is usually telling you the parent.
You can also add a separate device to map the routes, but most people don’t do that.
I have had several request about how I map my ZigBee network with Digi’s XCTU software so I thought I would share a quick how to:
Caution: This is not a Digi supported procedure if something goes wrong during the firmware upgrade you could brick your Digi USB xStick and have to send it back to Digi to be recovered.
What is this and why would you want to do it?
ZigBee mesh networks are self configuring and self healing and in larger networks it helps to know what nodes are routing who’s information. You can’t really control the network configuration but it helps to see the relationship between your nodes if your troubleshooting a connection problem.
The screen capture below is how my SmartThings ZigBee network looks when it is mapped out by the XCTU software. The SmartThings hub is th…
