Xiaomi Aqara Zigbee Switch DTH--help needed
Hello veeceeoh
I have the WXKG02LM switch
I am trying to add automations (in the smartthings app)
Why I do not have the option to act by a switch side (right or left)
Explain The two buttons do the same thing
Hello Avi_Hasui
May I know which DTH you are using with your WXKG02LM switch?
I use DTH v0.9.2
In a message from veeceeoh on this post
meantime I found a solution using WEBCORE
Hi,
just installed the DH v0.9.2 on the ST v3, the WXKG02LM is recognized, but both buttons act the same, and I see options for one button only.
Any suggestion?
I automated mine through the classic app, which will be gone soon. Now I see I need to redo soon it using WebCore.
I have transferred my automation for the Aqara 2 button switch to WebCore and it is working.
Thanks, I will give WebCore a try.
Wow, webCoRE is awesome! It really gets ST to a new level.
Resuming this thread because despite with WebCoRE I have been able to use the Aqara 2 button switch, sometimes the switch goes into a strange status: when pressing the button the relative led blinks twice but no signal is sent. The app sees it connected but not receiving commends.
The only solution is to remove and connect again.
Have you guys notices such a behaviour?
I have the same problem
This is probably a communication problem
There is a need to buy another component that will add to the Zigbee network
same as
https://www.aliexpress.com/item/4000812808720.html?spm=a2g0o.productlist.0.0.32e33a9bsV7srX&algo_pvid=aee00a4e-8715-4f6f-9f0d-afdaa704eb23&algo_expid=aee00a4e-8715-4f6f-9f0d-afdaa704eb23-2&btsid=2100bdec16050134774113801e05a8&ws_ab_test= searchweb0_0, searchweb201602_, searchweb201603_
Or any component that used as a repeater
Any News to this - Is the only way to use Webcore - As the new app you can not choose if button 1 or 2 is pushed - it reacts the same - I have the 2018 2 buttons model ?
Any help?
Hi!
Do you have any solution to why only 1 button work on the WXKG02LM 2018?
I see that there are alot of people with the same problem.
What is the webcore solution all about?
If you using Webcore, you should be able to make both buttons to work and make the Held functions to work aswell.
Hi i’m newbee in SM.
There is code for the Aqara, Single Switch Module T1 (With Neutral)?
I searched but could not find it
TNX for help
