yeah, i have an iphone… that app seems really limited. take a look at this smartapp that is way more advanced, and free: Rule machine - as per the app developer, this app is no longer available for new installs, distribution, or support
i don’t really understand how you have things set up. what is a widget area? a routine? are you using myQ? the myQ has an issue where if you send an open signal to both doors at the same time only one will open. the open/close signal needs to be spaced apart by a minute or it doesnt work.
