Yeah… um…well…this is bug in the program. The program is really a very simple little bit of code. You just setup your switches, and the program watches for any one of them to turn on or off. When that happens it turns ALL of the switches on or off.
So, let’s say you have two switches, A and B, tied together. You turn on A… the program see this and sends out a command: Turn on switch A, and turn on Switch B. Switch A is already on, so nothing changes there. Switch B was off, so it turns on. But wait! The program just saw Switch B turn on… so it sends out a command: Turn on switch A, and turn on Switch B.. Both switches are already on, so no big deal, no problems there.
But, what if you go into a room, turn on Switch A, but then immediately think: “Wait, that’s dumb… I wanted to go into that room, not this one.” So you flip off Switch A. But, because there is a slight lag in SmartThings, this happens:
ST sees A is turned on, sends command: Turn on switch A, and turn on Switch B.
but before Switch B turns on, switch A is physically turned off, so:
ST sees A is turned off, sends command: Turn off switch A, and turn off Switch B.
But before this command is received, the previous switch on command is sent to B
ST sees B is turned on, sends command: Turn on switch A, and turn on Switch B.
Again before this on command is sent, the off commands are received and the switches turn off, so…
ST sees A (or B, or both) is turned off, sends command: Turn off switch A, and turn off Switch B.
…and on and on we go until there’s finally enough lag between commands that things settle down or you uninstall the program or remove one of the switches and update (and then add it back in later).
It doesn’t happen often, only when there’s real quick on/off action on one switch or if over lapping commands happen from different sources (for example, when I turn off my hallway light at the same time I open my door which is setup to turn ON my hallway light).
Ideally the program should be written in a way that it differentiates each switch in the group and when switch B turns on commands are only sent to switches A and C AND ignores the fact that those lights just turned on. But something like this is much more complicated and probably beyond my meager abilities with an open ended program that allows for any number of switches to be linked.
I may write a revised program that ONLY lets two switches be linked together. I anticipate that this is really the way the most people are using the program. And in this case it would be relatively easy to set it up as discrete subscriptions which point to discrete procedures rather than “If you see any on/off, then send on/off commands to EVERYTHING.” This should reduce the possibility of getting into the ‘freakout loop’, but until I can figure out a way to ignore the fact that a switch was turned on/off by my app and so don’t fire the command, it won’t eliminate it.
