Hi,
I’m pretty new to Groovy, but believe I’ve mostly figured out how to develop when I need.
What I’m trying to do now is write an app that counts the number of motion events from sunset to sunrise and send out a notification of the count at sunrise.
I have it working with a single motion sensor, but I’m trying to get fancy and do it for any number of motion sensors, and using a map to store the count.
The problem I’m having is that the map doesn’t persist through different functions. So when I try to call a “get” method on my map and assign it to an integer, the app dies because I’m trying to assign a null to an integer.
Here’s the app:
* Count Motion Events
* Copyright 2014 Top Lertpanyavit
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
definition(
name: "Count Motion Events",
namespace: "topl",
author: "Top Lertpanyavit",
description: "Counts number of motion events for a motion sensor from sunset until sunrise and sends push notification of count at sunrise.",
category: "My Apps",
iconUrl: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience.png",
iconX2Url: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience@2x.png")
preferences {
section("Motion sensor(s) to monitor..."){
input "motions", "capability.motionSensor", multiple: true, required: true
section ("Zip code for sunset and sunset times (optional, defaults to location coordinates)...") {
input "zipCode", "text", title: "Zip code", required: false
section("Notify me...") {
input "pushNotification", "bool", title: "Push notification"
def installed() {
log.debug "Installed with settings: ${settings}"
initialize()
def updated() {
log.debug "Updated with settings: ${settings}"
unsubscribe()
initialize()
def initialize() {
subscribe(motions, "motion.active", motionActiveHandler)
// Initialize countMap
// Set counts to 0
state.countMap = [:]
motions.each { motion -> state.countMap.put("${motion.displayName}", 0)
int count = state.countMap.get("${motion.displayName}")
log.debug "${motion.displayName}: $count"
setInitialConditions()
// Set initial conditions
def setInitialConditions() {
log.debug "Executing setInitialConditions()"
def sunInfo = getSunriseAndSunset(zipCode: zipCode);
def now = new Date()
def sunriseTime = sunInfo.sunrise
def sunsetTime = sunInfo.sunset
log.debug "Now: $now"
log.debug "Sunrise Time: $sunriseTime"
log.debug "Sunset Time: $sunsetTime"
if (sunriseTime.after(now)) {
log.debug "runOnce sunriseHandler() at $sunriseTime"
runOnce(sunriseTime, sunriseHandler)
log.debug "runOnce sunsetHandler() at $sunsetTime"
runOnce(sunsetTime, sunsetHandler)
sunsetHandler()
else if (sunsetTime.after(now)) {
sunriseHandler()
else {
sunsetHandler()
// Schedule next sunset/rise times check
scheduleGetSunTimes()
// Schedule sunset/rise times check
def scheduleGetSunTimes() {
log.debug "Executing scheduleGetSunTimes()"
// Scheduling for 1am local time every day
def scheduleTime = timeTodayAfter(new Date(), "01:00", location.timeZone);
log.debug "schedule getSunTimes() at $scheduleTime"
schedule(scheduleTime, getSunTimes)
// Get sunset/rise times
def getSunTimes() {
log.debug "Executing getSunTimes()"
def motionActiveHandler(evt) {
log.debug "Executing motionActiveHandler()"
log.debug "$evt.name: $evt.value"
// Debug block
int count = state.countMap.get("${evt.displayName}")
log.debug "$evt.displayName count: $count"
state.countMap.put("${evt.displayName}", count + 1)
def sunriseHandler() {
log.debug "Executing sunriseHandler()"
countMap.each { name, count -> sendMessage("$name detected $count motion events last night") }
unschedule("sunriseHandler") // Temporary work-around for scheduling bug
def sunsetHandler() {
log.debug "Executing sunsetHandler()"
log.debug "Resetting count to 0"
motions.each { motion -> state.countMap.put("${motion.displayName}", 0) }
unschedule("sunsetHandler") // Temporary work-around for scheduling bug
def sendMessage(msg) {
log.info(msg)
if (pushNotification) {
sendPush(msg)
The issue is in this section of code:
// Debug block
When I try to retrieve the count values from the map again, it’s showing all values to be null.
Any help?
Top
