@Mariano_Colmenarejo
Mariano, is there any way the Ikea motion sensors can report better battery information, they are really annoying, if they do not report in for a set inbuilt interval the battery report drops to a level where ST shows battery nearly flat, for example 11% but as soon as the sensor reports motion, a new signal is sent and the battery jumps to 56% ( example)
is this a hub FW issue, Ikea motion sensor issue or is there something in the driver that can be changed to help resolve what is correct out of the 2 readings
Try with this driver version
You may have to pair again if you see that it is still wrong
βββββββββββββββββββββββββββββββββββββββββββββββββββ
Name Zigbee Motion Sensor Mc
Version 2023-10-04T20:58:37.149109708
Hughβ¦thats a bit odd
smartthings edge:drivers:install is only showing Smartthings beta drivers, nothing else ?? logcat shows all drivers, any thoughts !
No, my bad, i expected to see the list of drivers after :install, found my mistake
Nope didnt make a mistake, i see the list of ST beta drivers but nothing else
agreed Mariano, all i am seeing after driver:install is Smartthings beta driver
One single entry out of many ?? very odd
already tried hub reboot
Ah, wait a mo, i think i know what i have done, back in 2 mins
Self inflicted mistake, i un enrolled all drivers except ST Beta a while back, totaly forgot i had done it, driver installed will do some testing Mariano and report back, thank you for the update
Hi Mariano, hope your day is going well, the Ikea motion sensor appears to be much better now, there has been a 9hr gap between movement events and the battery level remained at a constant 66% throughout
A secondary Ikea sensor has now auto updated the driver and again appears stable and reporting a constant battery level
Thank you for taking the time to look at the driver
Buen dia Mariano, he utilizado tu Driver Edge Zwave and Childs Mc con los interruptores sencillos y los dobles y estos me funcionan de maravilla, pero con los interruptores triples de MCO no me funcionan. Me toca utilizar el driver de MCO y este me muestra el triple como 1 solo dispositivo y quisiera que me los separara como lo hace tu driver.
AΓ±adido a esta versiΓ³n del driver
Espera a que se actualice el driver en tu Hub, maximo 12 horas
Name Z-Wave Switch and Child Mc
Version 2023-10-06T19:15:13.044840208
- id: 0298/13F1/140F
deviceLabel: Three Switch
manufacturerId: 0x0298
productType: 0x13F1
productId: 0x140F
deviceProfileName: switch-multicomponent-3
Mi amigo, De antemano te agradezco mucho. Ya logre probarlo en varios interruptores triples y se hace la separaciΓ³n sin problemas. Y al momento de pulsar el boton del switch2 y del switch3 me enciende independiente cada uno, pero cuando le doy al switch1 me encienden todos 3 botones :-(.
Hi Mariano,
I am an extremely amatuer about all smartthings. It was somewhat relatively idiot proof when i set it up, issue just arose.
These are information iβve found on my dashboard.
Do you know how I am suppose to view / show you the details you need?
I have a couple of 2gang / 3gang switches that are currently not working, only one of the switches are.
Iβve attached an example below for your perusal.
I am currently using the zemismart switches.
This is my product:
Iβve seen something like this on their webpage however, iβm not sure how to link them either.
I am getting this error feedback at the top when i try to change the driver:
βError changing device driver to βZigbee Thing Mcβ. Ensure that the driver you are trying to change to has a valid fingerprint match with this device.β
When you post the manufacturer code and model for three switch then I will add too
To device works fine you need delete device with app and pair again with this driver version
Name Zigbee Multi Switch and Child Mc
Version 2023-10-27T16:20:11.209671453
- id: "TS0002/_TZ3000_k8kkhcik"
deviceLabel: TS0002 Two Switch
manufacturer: _TZ3000_k8kkhcik
model: TS0002
deviceProfileName: two-switch
Mi amigo, me sale igual, pero solo ocurre con una nuevas versiones de switches triples. Aca esta la huella del dispositivo en el que me esta ocurriendo.
Me sigue sucediendo que cada vez que le doy encender al dispositivo principal. En vez de encenderme como individual, me enciende como MAIN, es decir, enciende los otros 2. Esto ya deja de ser funcional al momento de querer encender mis dispositivos como individual.
Esta version deberia resolver el problema.
Se actualizarΓ‘ automaticamente en 12 horas maximo
Version 2023-11-02T09:10:42.369969004
