Hi.
Where can I find the latest Webcore code?
I need to upgrade the version.
thanks
Hi.
thanks
The links to the code on github can be found in the following installation guide:
I decided it was about time to upgrade webCoRE after almost a year of using it. I went through the process in the above link, and it appeared to update and publish fine. The version is still showing as v0.3.110. Is that the latest version? Are newer releases coming?
v0.3.110.20191009 is the latest version.
newer versions - at some point yes
New version announcements are posted on the webcore forum
