I’ve got a very simple piston, that when a condition is met, changes the variable from No to Yes. The variable acts as a flag for other pistons to meet conditions
This piston worked, for a day. Then now, no matter how many times I get it to trigger, the variable value does not change at all.
Yes it does set it to No - at the moment they are disabled.
I need this one piston to set it to Yes, and from the looks of it I cannot see why it’s not
Yes that is correct.
This piston is not changing the variable to the value I want.
I have just deleted the variable, and recreated it with the value No. Executed this piston to change it to Yes. Checked the Global Variable value and it remains as No.
Okay, I can confirm this did not work either.
Something is really wrong, quite sure it’s me not getting the piston above to work or there is a bug somewhere.
you’re right, this piston is created to just change the boolean value so I can test the actual piston i want to work
the piston below is what i want to work, but it never worked because previously the variable never switched from Yes to No. I’ve now tweaked it as per your suggestion, Boolean true false and will give it a go.
