I want to connect with my hub via Powershell but every time when it tries to connect the is a timeout. And i dont know why. My PC found the hub and i authorised the connection but it just doesn’t want to connect. Any help?
Connect to your hub using what method?
I want to connect with CLI in the Windows Powershell. But when it tries to connect it always times out.
I haven’t tried Powershell. I run it in a normal command window. When you first ran the CLI, did a browser open for you to log in and authenticate your session?
Yes the authentication worked but after that it timed out. What kind of commandline program do you use?
Just a normal terminal/command window. Use search and type “command”.
