Voice control existing remote controls w/ST and GHome
Are both the fan & light controlled with ONE in wall switch or two.
If separate you can use a dimmer or on / off wall switch for the light and appropriate bulbs and the fan switch needs to be specifically Fan control switch (works as a dimmer) to control the fan speeds.
There are many threads regarding fan / light config’s …
Here is one:
