ady624:
Thank you. While I am aware of the z-wave/zigbee incompatibility, I was (vaguely) asking whether ST can in fact sense pushed buttons on it, therefore acting as the middle man in this whole business. I can take it from there, but it appears it works with its own controller and does not allow low-level button control to ST. Was hoping I can use that in lieu of a ZWN-SC7 which I honestly dislike because of its appearance. Just looks ugly to me. The RFWC5 on the other hand…
It’s very expensive, but the Leviton VRCS4 Will work as a button controller with smartthings. You might like the aesthetics better. It’s definitely higher quality engineering than the Enerwave.
https://www.amazon.com/Leviton-VRCS4-M0Z-4-Button-Remote-Controller/dp/B0050T2O1O
I’ve created a device type for the Leviton Vizia VRCS4 Scene Controller. Because of the way the scene commands work, I essentially turned it into a 4 button remote, 3 if there is a built in relay.
Setting it up is a bit of work:
Note: buttons are numbered 1-4 and dim, with dim at the bottom.
To associate, press and hold buttons 1 and 3 on the VRCS4 for 5 seconds, the LEDs will start to flash amber. Hold the SmartThings Hub near to the device tell the SmartThings app to connect a new device. Note: you tell the device to connect before the hub. The hub should find a ZWave Remote. This will eventually be your scene controller.
If you have a load connected to the VRCS4 (hardwired):
Go back to the SmartThings app dashboard. Press and hold buttons 2 and 4 on the VRCS4 for 5 seconds. The le…
