Update preferences field from code
Hi All,
Is there any way to dynamically fill a preferences field from code?
In my SmartApp, I am expanding on @brianwilson’s ThingSpeak code, but making the interface a little more user-friendly by automatically creating a channel on the user’s behalf.
My approach is to give the user an option to use an existing channel or create a new one. That means that I have options in my settings for “Channel ID” and “Channel Key”, but if those are empty, I create a new channel. I would like to fill in those fields once I create a channel and then use those values for my actual POSTs.
Does anybody know how to do this? Are preferences uni-directional?
Thanks,
Dan Kurin
Other than setting a default, I do not think it’s possible to programmaticly change these.
Hopefully someone will chime in and say I’m wrong…
I don’t know if this will work, but it’s worth a shot. I think I’ve seen this method work for options:
In the options for the input, set default to a function. Then return the value you want in the function.
default: getName()
def getName() {
     return 'name-' + preference1 + '-' + preference2
Let me know if this works.
Here’s my solution.
I use a dynamic page and set the description as a state variable (to my knowledge, “Default” is only available for device handlers)
input(name: "channelID", type: "number", title: "Channel ID", required: false, description: state.channelID)
input(name: "channelKey", type: "text", title: "Channel key", required: false, description: state.channelKey)
Then in my installed(), I check to see if either field is filled, otherwise I create a new channel:
if (channelID != null || channelKey != null) {
    state.channelID = channelID
    state.channelKey = channelKey.toUpperCase()
} else {
    createChannel()
In my updated(), I check again to see if the user specified a channel, otherwise we use what’s already in state:
Because I’m using “Description” instead of “Default”, the returned value is still null even though text “appears” in the input box.
It’s a little hacky, but it serves the purpose. Any feedback?
It appears you can now use:
app.updateSetting(inputName, [type: type, value: value])
app.updateSetting(inputName, value)
// or for DTHs:
device.updateSetting(inputName, [type: type, value: value])
device.updateSetting(inputName, value)
However, while the above code seems to be able to change settings with existing non-null values, it does not appear to be able to add values to settings that are currently empty. So half-way there at least…
I wouldn’t expect a ton of responses regarding this, though it’s huge. Unless you’ve tried writing some pretty complex apps/handlers most wouldn’t even understand the implications here…
Thanks for the update!
